interoperate with derived type
I have three structs in C
typedef struct TYPE1_T {
    type2_t params;
    type3_t *status;
} type1_t;
typedef struct TYPE2_T {
    int idx;
    int size;
} type2_t;
typedef struct TYPE3_T {
    int idx;
    int size;
} type3_t;
Is it possible to create an interoperable types in Fortran 2003? I’m not sure as there is one pointer in the second component of type1_t.
Tuan
Hi Tuan
I fairly sure that pointers and allocatable are not allowed in bind© derived types. I also don’t think you can have other derived types either since each component of a derived type must ne an ISO_C_BINDING interoperable type. Though, I’ll ask when I’m back in the office on Monday since I’m not positive.
  • Mat
Thanks, Mat. This is important as it is quite common in C code that I have.
Waiting for your confirmation.
Tuan
Hi Tuan,
This was a good exercise for me since I haven’t had the opportunity to work with ISO_C_BINDING. I was correct in that you can’t have derived type pointers but you can use regular C_PTR types and then use the function “c_f_pointer” to associate the C pointer with a local pointer to the derived type.
For example, main.c
#include <stdio.h>
#include <malloc.h>
#define N 10
    int idx;
    int size;
} type3_t;
    int idx;
    int size;
} type2_t;
  type2_t params;
  type3_t *status;
  int idx;
} type1_t;
void fortran_func_(type1_t *, int);
int main() {
  type1_t A;
  A.idx = 0;
  A.params.idx = 0;
  A.params.size = 0;
  A.status = (type3_t*) malloc(sizeof(type3_t) * N);
  for (int i=0; i<N; ++i) {
    A.status[i].idx = 0;
    A.status[i].size = 0;
  fortran_func_(&A, N);
  printf("%d %d %d\n", A.idx, A.params.idx, A.params.size);
   printf("%d %d\n", A.status[i].idx, A.status[i].size);
  free(A.status);
fexam.f90
subroutine fortran_func (Aptr, N)
  use iso_c_binding
  type, bind(c) :: type2_t
     integer(c_int) :: idx, size
  end type type2_t
  type, bind(c) :: type3_t
  end type type3_t
  type, bind(c) :: type1_t
     type(type2_t) :: params
     type(c_ptr) :: status
  end type type1_t
  type(c_ptr), value :: Aptr
  type(type1_t), pointer :: A
  type(type3_t), dimension(:), pointer :: status
  integer, value :: N
  integer :: i
  ! Assocatate the C "Aptr" pointer to a local fortran
  ! pointer to type1_t
  call c_f_pointer(Aptr,A)
  A%idx = 1
  A%params%idx = 100
  A%params%size = 1000
  ! Associate the 'status' type1_t pointer to A%status
  ! You must add a shape arguement (N) since its an array
  call c_f_pointer(A%status,status,N)
  do i=1,N
     status(i)%idx = i
     status(i)%size = N-i
  enddo
end subroutine fortran_func
Running the code
% pgf90 -c fexam.f90
% pgcc -pgf90libs main.c fexam.o
main.c:
% a.out
1 100 1000
1 9
2 8
3 7
4 6
5 5
6 4
7 3
8 2
9 1
10 0
I’ll work on the inverse (Fortran calling C) next.
  • Mat
Here’s the inverse, Fortran calling C
fmain.f90
module type_mod
  use iso_c_binding
  end type type2_t
  end type type3_t
  end type type1_t
end module type_mod
program test_f_to_c
  use iso_c_binding
  use type_mod
  interface
     subroutine init_data(A,N) bind(c)
       use iso_c_binding
       use type_mod
       type(type1_t) :: A
       integer(c_int), value :: N
     end subroutine init_data
  end interface
  integer, value :: N
  parameter(N=10)
  type(type1_t) :: A
  integer :: i
  call init_data(A,N)
  print *, A%idx, A%params%idx, A%params%size
  do i=1,N
     print *, i, status(i)%idx, status(i)%size
  enddo
end program test_f_to_c
init.c
#include <stdio.h>
#include <malloc.h>
    int idx;
    int size;
} type3_t;
    int idx;
    int size;
} type2_t;
  type2_t params;
  type3_t *status;
  int idx;
} type1_t;
void init_data(type1_t * A, int N) {
  A->idx = 1;
  A->params.idx = 10;
  A->params.size = 100;
  A->status = (type3_t*) malloc(sizeof(type3_t) * N);
    A->status[i].idx = i+1;
    A->status[i].size = N-i;
% pgf90 fmain.f90 init.c ; a.out
fmain.f90:
init.c:
            1           10          100
            1            1           10
            2            2            9
            3            3            8
            4            4            7
            5            5            6
            6            6            5
            7            7            4
            8            8            3
            9            9            2
           10           10            1
Could you please check the init.c code, it’s written in Fortran, right? I guess you copied the wrong text.
Tuan
Sorry, cut and paste error. I went back an updated the code.
  • Mat
Hi Mat,
May I ask you the interoperating type in C of a Fortran device data
double precision, dimension(:), device:: data
Suppose that I have the function (in C) that return data on device memory
void foofunc(uint64_t* d_data, n) {
    cudaMalloc(d_data, sizeof(uint64_t) * n)
To interoperate with this function in Fortran. I tried this yet it doesn’t work?
subroutine fortranfunc()
double precision, dimension(:), allocatable, device :: d_data
interface
   subroutine foofunc(d_data, n) bind(c)
       use iso_c_binding
       integer(c_int64_t) :: d_data
       integer(c_int) :: n
   end subroutine
end interface
n = 10
call foofunc(d_data, n)
end subroutine
Thanks,
Tuan
Hi Tuan,
I think all you need to do is to change
       use iso_c_binding
       integer(c_int) :: n
   end subroutine
to
       use iso_c_binding
       double precision, dimension(:), device :: d_data
       integer(c_int) :: n
   end subroutine
A “device” array is really just a CUDA C device pointer so don’t need the ISO_C_BINDING here.
  • Mat
    [/code]
Thanks, Mat.
Could you please help me to make clear what’s the difference between using
with the new type type(cudaArrayPtr)
type(cudaArrayPtr) :: d_data
that I read in the manual. Unfortunately, there is no documentation on this datatype. So I’m not sure on using it.
Thanks a lot,
Tuan
