• Hardware Platform (Jetson / GPU) - Nvidia T4 GPU • DeepStream Version - 5.1 and 6.0 • JetPack Version (valid for Jetson only) – • TensorRT Version. 8.0.1-1+cuda11.3 • NVIDIA GPU Driver Version (valid for GPU only) 460.32.03 • Issue Type( questions, new requirements, bugs) bug • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
This pipeline downscales input videos to 608x608 resolution with padding. interpolation-method in streammux element does not have any effect - changing it does not yield different result. This is important because my neural network is trained with bilinearly scaled-down images and the results are worse with default nearest-neighbors interpolation.
I was able to do proper scaling with Gst-nvvideoconvert element in pipeline below.
Both streams are 4k resolution. Horizontal is 3820x2160 and vertical is 2160x3840. They are using motion JPEG encoding instead of H264 - I have dumped images with the pipelines presented above - there are no encoding/decoding artifacts - this issue is about the interpolation method.
If you recreate those pipelines you will see that this flag (in streammux element) does not have any effect.
I have done it right now. I see there are some differences (very minor) between interpolation methods. However the images that come from this deepstream pipeline have less detail than images downscaled by OpenCV - there are some weird compression artifacts visible - even though I am comparing images that does not come from video source. This is the pipeline I am using for deepstream:
And this is how images are downscaled for model training:
dim = (width, height)
resized = cv2.resize(img, dim, interpolation=cv2.INTER_LINEAR)
The whole goal of this issue is to solve why deepstream produces predictions with less accuracy and recall than raw TRT engine - we were lead to believe that this is due to the downscaling method. Might there be a different reason?
Can you recreate the pipeline and explain why deepstream images have less detail than OpenCV ones (even though the algorithm used is the same - bilinear scaling)?
Hi, I have verified this behavior with the following drivers: NVIDIA-SMI 470.57.02 Driver Version: 470.57.02 CUDA Version: 11.4.
Do you know what interpolation-method should I specify to get the same results as OpenCV: resized = cv2.resize(img, dim, interpolation=cv2.INTER_LINEAR) ?
If the resizing is not the reason of the precision degradation of deepstream pipeline (in the case of inference precision and recall) what could the reason be?
