The laptop is running great with the nvidia drivers. The only problem I’m having is that it seems like the Nvidia drivers are causing an interrupt storm on interrupt 61 making a kworker thread go nuts on one of the CPU cores. Simply disabling the interrupt, makes things go back to normal and it doesn’t look like there are any issues with the laptop in a day to day usage. The reason I’m “blaming” the nvidia drivers is because it was working fine before installing them.
Recently I came across this bug report if it is of any help.
https://bugzilla.kernel.org/show_bug.cgi?id=155831
Every time I reboot the laptop I of course have to disable the interrupt, so I was hoping the issue could be fixed at some point.
