In my design, I use un 10inch universal LCD with HDMI interface and capacitive multitouch. This is powered from +5V of Jetson TK1 board. Entire system is powered from +12V battery (LiPO type, 1800mAh) and works OK.
After Shut-Down the +5V isn’t interrupted and the power consumption of the DISPLAY (including back-lite!) is important and the battery is too fast discharged too fast. I cannot use a bigger battery and intend to include a power-off switch circuit with about 20 seconds delay so that to be interrupted the connection from battery. I think my solution isn’t one elegant and exactly solution…
Here are my questions:
a) Is it a signal on Jetson TK1 (maybe on GPIO), that can be used, after Shut-Down, for a command of the delay circuit (instead to chose an arbitrary delay with big capacitor or 555 timer)?
b) Is it a better solution with minimum of components, because I didn’t have sufficient space just for a small supplementary board?
Thank you very much for your advices.
Have you a very good year for many designs with Jetson TK1!
JB
