Thank you for the very detailed response, I appreciate it. It certainly enriched my understanding.
The NVLINK I ordered arrived today. It seems like I am able to use cuMemSetAccess in order to make cuMemcpyDtoDAsync work. (cuMemSetAccess failed with CUDA_ERROR_INVALID_DEVICE beforehand).
Glad to help, I hope you’re happy with your purchase!
Yeah, in this case, cuMemSetAccess will fail with CUDA_ERROR_INVALID_DEVICE if any of the mapped allocations in the requested VA range’s physical location cannot be mapped by that device. You can check this easily at runtime by querying the attributes of the memory either with cuPointerGetAttribute or cuMemGetAllocationPropertiesFromHandle, retrieving the device ordinal for the source allocation and using cuDeviceGetP2PAttribute with the source device and the target device to see if P2P is supported.
Hey again Cory,
I’ve been having additional issues, wondering if you could shed some light.
I’ve been trying to understand performance issues that I’m having, I’ve created a simple program to debug the essence of it.
This program (which is attached) performs cuMemMap and cuMemUnmap in a for loop in a few threads.
If a single thread is running the average runtime for cuMemMap and cuMemUnmap is about 50us, while few threads are running the average runtime increases and sometimes even reaches 18ms!
I would like to ask if there are any reasons for that to happen and besides running as a single thread is there a way to avoid those runtime spikes.
So, looking through your sample application, I see you’re manipulating the address space of different contexts, but the same device. The CUDA Virtual Memory Management APIs manipulate the process-wide unified VA space, so you’re going to get lock contention from each of those threads, both in manipulating the UVA space and the device’s own page tables. The locks protecting these internal resources aren’t fair either, so it wouldn’t be a straight (N*50 us) where N is the number of threads since threads can release the lock and re-acquire the lock in any of the other calls manipulating the VA space for that device.
That said, cuMemMap itself should be fairly fast barring lock contention. cuMemSetAccess and cuMemUnmap (assuming there is a READWRITE mapping on the address range requested) would be the costly APIs, as those interact with the OS to perform the page table updates.
Hey Cory, thanks for the detailed response.
It seems reasonable that lock contention or OS interaction might be the problem here.
We’re still having trouble solving the problem at hand. Do you happen to know if NVidia offers paid consultancy on these CUDA-internal issues?
We haven’t forgotten about you, don’t worry! One thing you can do is use any one of our profiling tools distributed with the CUDA Toolkit to profile your application. This should show in the timeline view any locks taken, even internal driver ones, which should give an understanding if there’s any lock contention.
As to paid consultancy on these issues, we’re talking with some folks and should be able to provide some information off this thread shortly.
My team and I tried using NVidia’s profiling tools, as you suggested. We’ve used various tools, and narrowed down the causes of the spikes we’re experiencing.
cuMemUnmap and cuMemSetAccess do seem to hang in pthread_mutex_lock, which could cause starvation in the code example I’ve given above (given that Linux mutexes are unfair). However, in our actual use-case, most threads are not busy 100 percent of the time. Our internal calculations indicate that in our actual use-case, starvation wouldn’t be longer than 6.5ms, however we experience jitters of up to 15ms.
We profiled lock contention and ioctl times inside our framework. We hooked pthread and libc’s ioctl, and each time it took more than 1ms to acquire a lock, or perform a ioctl - we logged it. We saw direct correlation between long lock times and long ioctls. As I see this - it means long ioctls to NVidia’s driver made other APIs block, which is reasonable.
Specifically, we noticed that 3 ioctls seem to sometime cross the 1ms threshold (and up to 15ms):
0x21 and 0x22 to /dev/nvidia-uvm (cuMemSetAccess, cuMemUnmap).
0xc020462a to /dev/nvidiactl (this one is called from cuDeviceGetAttribute, which is called from libcufft).
Furthermore, we noticed that if we run nvidia-smi while our program runs, we instantly experience contention.
As usual, we have several questions:
Is there any reason to repeatedly call cuDeviceGetAttribute? Are any of the values subject to change between subsequent calls? Why not cache these values?
Is there any way you can think of, to reduce the jittering of the ioctls performed by the virtual memory APIs? What exactly do these ioctls do, perhaps we can change some Linux configuration to make them more stable?
There are some dynamic values returned by cuDeviceGetAttribute, not all of them are static unfortunately. While there have been a few that were needlessly dynamic and have been fixed in recent drivers others like CU_DEVICE_ATTRIBUTE_CLOCK_RATE, CU_DEVICE_ATTRIBUTE_MEMORY_CLOCK_RATE or CU_DEVICE_ATTRIBUTE_KERNEL_EXEC_TIMEOUT can change over time. Additionally, querying the amount of free memory available via cuMemGetInfo() also requires an ioctl to retrieve (and it’s highly recommended not to use this feature in production software).
These APIs require OS interaction to perform the mapping operation. What you’re effectively asking is equivalent to asking “can the linux kernel reduce the jitter of the mmap() function call?”. In both cases, the OS takes shortcuts based on the available (and sometimes cached) resources on hand, and the apis scale with the size of the request. Finally, there’s the issue of the ioctls being serialized via locks as well which we are improving on in later drivers, but I don’t expect this to be fully parallelized in the near future. The shorter answer here is, we are always working on improving the performance and reducing jitter in our API calls, but I wouldn’t expect it to be eliminated or even reduced significantly in the near future.
Yes, this is a known issue that is not specific to the CUDA Virtual Memory Management APIs. It isn’t just nvidia-smi, but any application that tries to access the kernel mode driver in various ways (i.e. another CUDA application) will take some shared kernel mode locks and be serialized with another process. The places where these shared locks are being taken are being reduced in later drivers, but there are a great many of such places.
Hey, thank you very much for your insightful answer.
This is, in fact, exactly what I’m asking. These API calls are opaque for me, I understand they require OS interaction, but I’m not sure which OS APIs do they use, exactly. The fact they actually interact with the operating system’s VM (i.e mmap) is great info. If you could further elaborate in what way do they interact with the OS, it would be incredible. We could try to fine-tune our OS to try and reduce this jittering. We’re currently looking at such solutions, but we’re doing so blindly.
As I’ve said in my previous comment, I don’t think this is the issue we’re experiencing. Sure, in the sample application this should be a bottleneck - but in our actual use-case this shouldn’t be a problem, let alone the problem.
If this was an issue in our actual use-case, I would expect to see jittering in various other ioctls, not only these three.
So, the ioctls involved on your platform in cuMemSetAccess (and in this case cuMemUnmap, as it internally calls cuMemSetAccess(PROT_NONE) to unmap the memory) are the UVM ioctls, which is open source (look for UvmMapExternalMemory when extracting the nvidia display driver package, the full source of this part of the kernel mode driver is readily available), so you’re free to inspect these paths yourself. Unfortunately, this path in particular ends up jumping into the proprietary binary blob, for which there’s not much I can give insight on in a public forum.
It really depends on what other ioctls you’re looking at, as some ioctls have different locking semantics than others (some have read/write semantics, others are plain exclusive). The fact that you said nvidia-smi makes your application slower is an indication this could possibly be your issue, but I can’t be sure without looking at your use case directly, and/or seeing a timeline profile.
You had asked about paid consulting before, and that might be the direction you might want to take in order to have someone dedicated to look into your particular use case and see what we can do to help. I’ve sent you a direct message with a contact that you can use to describe your problem in more detail with a representative more suited to guide your application development. I’ll also be in touch with them and see if we can’t resolve your issue so we can hopefully post the solution for others to enjoy.
Hey @jmak, I reached out but received some error from your exchange server. It couldn’t be delivered to some specific mail address (because it’s restricted). Not sure if my email arrived properly.
Is there support for these APIs in Windows systems as well? I’m having trouble with mine.
I’m using Windows Server 2022 with a single Tesla T4 GPU and NVIDIA driver version 516.01 installed.
At first I saw that the API cuMemAddressReserve succeeds but returns the address 0x0.
I then encountered the device attribute CU_DEVICE_ATTRIBUTE_VIRTUAL_ADDRESS_MANAGEMENT_SUPPORTED and querying the device for this attribute returned 0 as if this is not supported by the GPU.
As mentioned above, I’m using a Tesla T4 GPU which should support this feature.
I even verified that querying the same attribute for the same GPU type in a Linux machine returns 1.
I haven’t found any note that these APIs do not support Windows, and it also seems that the memMapIPCDrv CUDA sample supports Windows.
I wonder if this is something related to Windows or the GPU itself, and if I can somehow add support for this in my system.
Yes, but unfortunately only for WDDM driver model GPUs, which your Tesla T4 being a Tesla card only supports TCC driver model IIRC (more information about WDDM/TCC driver model can be found in the link below). This feature is supported on this GPU on native Linux platforms though if that’s an option for you. As to when or if this feature will be supported on TCC, I cannot say at this time, but I can say we’re actively looking into some options!
Thanks @Cory.Perry for the super fast answer. Much appreciated!.
Is there any place where I could see which GPUs support the WDDM driver model? Is there a general rule or should I check per GPU type?
From peeking at the nvidia-smi documentation you sent, it seems that TCC is more for compute-related GPUs while WDDM is more for graphics. Does it mean that any data-center GPU will not support the WDDM driver model?
It also seems that WDDM driver model has some disadvantages compared to TCC in performance.
I really hope you’ll manage to add support for these amazing features to the TCC driver model as well.
Thanks again and I’ll be waiting for any news regarding this in the future!
No worries, happy to help!
If you look at the nvidia-smi output, you can see the current driver model. With admin priviledges you can change the driver model on some GPUs, but IIRC all “Tesla” branded models do not support changing the driver model, but I don’t recall if that’s entirely accurate. I do know Quadro GPUs support switching driver models, and I believe drivers today require the GPU to have a display head (ability to connect to a screen, though an actual connection to a screen is not required) in order to use WDDM.
Most of the documentation surrounding TCC and WDDM touting lower performance are typically fairly old in my experience. Current drivers in WDDM can achieve comparative performance on par with TCC, and newer CUDA features like WSL support, these VMM apis, and many many more are only available on WDDM. For more up-to-date information on performance of WDDM, check out this other blog post by one of our lead CUDA Windows engineers, linked below! This blog post is mostly related to WSL, but there is information here about WDDM performance as well, and much of the performance benefits (and more) apply to native Windows WDDM as well. That all said, WDDM is a very different driver model from what most are used to with TCC and native Linux, and there are some caveats and pitfalls that one might run into. Most of these issues fall outside our CUDA Programming Model as defined (like buffering launches until synchronization rather than immediately). See the programming guide below for more information. I believe there’s also a few GTC presentations that go over WDDM performance tips as well that might be beneficial in this regard.
