Cheers,
I present you first public release of my Vulkan renderer :
https://github.com/pumexx/pumex
Pumex has few properties that you may find interesting :
- it enables multithreaded rendering on many surfaces and devices at once
- it's higly configurable - you may add new windows, devices and surfaces using few lines of code
- it's ready to render on VR gogles
- it decouples rendering phase from update phase and enables update step with constant time rate independent from rendering time rate
- comes with few examples showing :
- how to render lots of different 3D assets in a single draw call using vkCmdDrawIndexedIndirect()
- how to animate 3D assets
- how to use texture arrays and arrays of textures
- how to implement deferred rendering
- uses modern C++ ( C++11 and C++14 )
- works on Windows and Linux
- comprehensive documentation explains most important concepts of the Pumex renderer
- there are only few libraries that Pumex depends on. All of them are downloaded and built during first Pumex build ( that's for Windows version. Linux requires you to install three of them using package manager )
Feel free to check it out.
