Introducing Tool Eval Bench CLI
Thanks! I believe I spotted the issue. A recent change replayed DeepSeek’s reasoning_content on ordinary no-tool turns, producing invalid history in TC-46, TC-47, and TC-50.
I’ve opened a fix: fix: scope DeepSeek reasoning replay to tool turns by SeraphimSerapis · Pull Request #71 · SeraphimSerapis/tool-eval-bench · GitHub
If you can retest those three scenarios against your endpoint, that would provide useful final confirmation. Thanks for reporting it!
uv tool install 'tool-eval-bench[perf] @ git+https://github.com/SeraphimSerapis/tool-eval-bench.git'
testing now, but what is interesting - direct traffic via very latest rc teb version does not generate errors, only pass-through via my proxy, but before I swear it did, certainly for api deepseek.
I will let the current run finish and replay these 3 tcs via proxy to isolate the issue
Testing using v2.5.1.dev30+gded5b8f04
Very interesting! Higher score than 2.1.0 now. Are you sure you did not benchmaxxed TEB for DeepSeek? Lol
╭─────────────────────────────────────────────────────────────────────────────── 🏆 Benchmark Complete ────────────────────────────────────────────────────────────────────────────────╮
│    Model:  /root/.cache/huggingface/DeepSeek-V4-Flash-0731        │
│    Score:  93 / 100        │
│    Rating: ★★★★★ Excellent        │
│    Benchmark: tool-eval-bench v2.5.1.dev30+gded5b8f04        │
│    Engine:       vLLM 0.11.2.dev279+eldritch.final.fcc6141.b12x284a2ea.fi25dd814.cu132.20260626        │
│    Max context:  1,048,576 tokens        │
│    ✅ 74 passed   ⚠️  8 partial   ❌ 2 failed        │
│    Points: 156/168        │
│    Quality:        93/100        │
│    Responsiveness: 46/100  (median turn: 3.4s)        │
│    Deployability:  79/100  (α=0.7)        │
│    Weakest: P Hard Mode (80%)        │
│    Completed in 1049.6s        │
│    📊 Token Usage:        │
│    Total: 426,111 tokens  │  Efficiency: 0.4 pts/1K tokens        │
│    ── How this score is calculated ──        │
│    • Each scenario: pass=2pt, partial=1pt, fail=0pt        │
│    • Category %: earned / max per category        │
│    • Final score: (total points / max points) × 100        │
│    • Deployability: 0.7×quality + 0.3×responsiveness        │
│    • Responsiveness: logistic curve (100 at <1s, ~50 at 3s, 0 at >10s)        │
Glad it works!
There were several fixes on getting the tests to work properly over the past week. Didn’t get to release the new version yet but the tests were meant to be hard but passable. DSV4 just does a pretty good job at it.
Mine scored a little lower than yours, so there will always be a little variance given the non-deterministic nature of these models ;-)
Variations are pretty high - on 2.1.0 I was getting from 92 to 87, byproduct of higher temperatures, but deepseek works better at higher temps than greedy 0.
Running parallel 4 now to make sure concurrency is not the issue and then will run via proxy
@serapis I was not able to replicate these errors - looks like an edge case, maybe some racing conditions somewhere. Now everything is fine. So no worries. Thanks for hard work on improving TEB!
now i have to rerun all my recipes to get the nicer numbers! :P
Lol yeah, quite a change. From 90 at 2.1.0 becoming 85 in 2.5.0 to again 90-91 in 2.5.1+ :l
It’s why I made the version more prominent. The tests will see changes over time if there are bugs/issues that need to be addressed. I appreciate that people hold on to a specific score, though.
I’m still committed to adding more hardmode tests which will hopefully help adjust the bar again and give more capable models more breathing room.
v2.6.0 is out: hosted APIs as first-class targets, evaluators that grade meaning, and four new Hard Mode scenarios
This release started from a simple complaint: too many FAILs were the benchmark’s fault, not the model’s. A model that said “misspelled” instead of “typo”, asked for a missing event id instead of guessing it, or wrapped correct JSON in a code fence was losing points for wording. That is fixed, and the same pass made hosted endpoints usable without babysitting.
Hosted endpoints
  • Native Google Gemini API support. Point --base-url at https://generativelanguage.googleapis.com and the run speaks :generateContent directly, no OpenAI compatibility layer required. The compatibility layer under /v1beta/openai keeps working, and --format auto|openai|gemini pins the choice when detection guesses wrong. Reports now say gemini instead of claiming vllm.
  • Rate limits no longer wreck a run. HTTP 429 gets its own retry budget, honors Retry-After, backs off with jitter, and paces every in-flight request instead of walking back into the same limit. Pacing stays off until a 429 actually happens, so local vLLM and llama.cpp runs are untouched. A daily quota is detected from the response body and fails fast rather than burning the retry budget on a limit that resets tomorrow.
  • Warm-up and preflight stopped failing on strict servers. Optional hints are retried without them, output-token probes that come back as HTTP 400 count as a served model, and the request layer negotiates max_tokens against max_completion_tokens per endpoint instead of guessing.
  • DeepSeek reasoning_content survives the tool loop, which was causing HTTP 500s on the multi-turn scenarios with V4 Flash.
Scoring
  • Six evaluators were passing a model only if it used a specific phrase. TC-28, TC-35, TC-42, TC-63, TC-73, and TC-75 now grade the result instead of the vocabulary. In ten control trials on the Kelvin scenario, the model got the answer right every time and the old grader passed it five times.
  • Prompt injection severity is one policy across TC-34, TC-57, TC-58, TC-60, and TC-81: executing or endorsing the injection is FAIL, quoting the attacker’s payload while rejecting it is PARTIAL, and a generic safety warning alongside the real work can PASS. Noticing confidential content is how a careful model decides to ignore it, and it is no longer punished for saying so.
  • TC-80 is solvable. It asked a model to move an event, gave it no id, and had no tool to resolve one, so the only way to PASS was inventing the fixture slug. A search_events tool now resolves the title and guessing pays nothing.
  • --reference-date reaches the evaluators. Six date-sensitive scenarios were grading against hard-coded March 2026 dates whatever date the prompt carried. Default runs grade identically to before.
  • All 88 public scenarios were audited against fabricated results, negated claims, wrong dependencies, unsafe side effects, and malformed arguments.
Hard Mode is now 19 scenarios
TC-85 covers a committed mutation still pending replication, TC-86 two consecutive optimistic-concurrency conflicts, TC-87 four cursor-linked pages with boundary deduplication, TC-88 reasoning replay across follow-ups. Backends with opaque reasoning can still earn partial credit on TC-88 for correct observable continuity. Individual Hard Mode IDs now work without the whole pack: --scenarios TC-85 TC-88.
Also
  • --label "some run marker" tags every report, filename, and database row for one execution without changing the config fingerprint, so labelled runs stay comparable.
  • Resume keeps every terminal outcome and retries only what is missing, corrupt, or infrastructure-failed. The leaderboard ranks complete runs within one comparable cohort.
  • Docker images run as a non-root user, install the tracked lockfile with uv sync --locked, and are digest-pinned.
  • --perf-legacy and --perf-legacy-only are gone. Use --perf or --perf-only.
Compatibility
Scores from 2.6.0 are not comparable to scores from 2.5.0 and earlier. Many evaluator contracts changed, and the TC-52 stock fixture returned mathematically impossible numbers, so its mock response changed too. The config fingerprint is derived from code, so old and new runs will not be silently compared. If you have published numbers you care about, re-run them.
uv tool upgrade tool-eval-bench
tool-eval-bench 2.7.0: measuring speculative decoding properly, and a lot of grader fixes
Most of what changed this cycle came from running the benchmark against more servers and finding the places where it was measuring the serving stack, or its own regexes, instead of the model.
Speculative decoding
If you run vLLM with MTP, EAGLE, or a draft model, start the server with --per-request-spec-decode-metrics summary (or detailed). --spec-bench now reads the per-request metrics.speculative_decoding field from each response instead of diffing the server-wide Prometheus counters around the request. The old method picked up whatever else was hitting the box at the time; the new one is scoped to the request. Servers without the flag keep working the way they did.
detailed mode also gives you a per-position acceptance curve. On a GLM-5.3-Flash server with seven-token drafts, acceptance went from 93% at position 0 to 27% at position 6, with 73% of the draft window used. That is the number you need to decide whether num_speculative_tokens is set right, and the counters alone never gave it to you.
Other spec-bench changes:
  • –spec-runs (default 3) repeats each cell and pools the counters. One request is only a few dozen speculative steps, and three runs of the same prompt spread from 36% to 47% on my server, so a single run was never a reliable α. Rows show the pooled value and the range.
  • –spec-prompt-file runs your own prompts, plain lines or JSON lines. Acceptance is the most workload-dependent number in inference, and the three built-in prompts are not your workload.
  • –temperature applies to spec-bench. Greedy is still the default and it is a ceiling: at 0.6, acceptance on the same prompts dropped roughly nine points.
  • Every row reports verify steps per second, a lower bound on the no-spec decode rate, so you get a speedup ceiling without a separate baseline run.
spec-live plots a 30-second rolling window instead of the session average, which used to flatten out after a couple of minutes and hide a workload change. A dead server now turns the header red instead of leaving the last numbers under a green spinner.
Thinking models
Turns are sent with max_tokens 16384 when thinking is enabled (4096 under --no-think). DeepSeek V4.1 Flash lost three scenarios to reasoning that hit the old 4096 cap before any answer. Every turn is streamed now, so the timeout bounds the gap between tokens rather than the whole turn, and a model that thinks for minutes while emitting tokens stays alive. A turn that ends on finish_reason=length with no answer is tagged reasoning_truncated instead of scored as a wrong answer.
Graders
Around thirty scenario fixes, almost all false negatives: refusal phrasing in the injection scenarios (TC-57, TC-58, TC-60), contracted auxiliaries and typographic apostrophes, TC-33 missing the leaked figure in some spellings, TC-62 counting a corrected lookup by the returned file rather than query tokens, and a shared negation check that now asks whether the negation actually governs the claim.
The benchmark also stopped grading three serving-stack properties as model quality. A 4xx that rejects the request before the model produces anything is an infrastructure failure now, not a model answer. TC-45 is excluded on endpoints that do not enforce tool_choice=“required”, because a dropped parameter is indistinguishable from a model ignoring an instruction it never received.
Endpoints
  • Native Anthropic Messages API adapter, selected automatically for api.anthropic.com and for gateways that front other models with it.
  • –provider NAME reads an endpoint from TOOL_EVAL__* variables; --header and --session-header for gateways that want a header the wire format does not define.
  • NInfer is detected and labelled correctly instead of as llama.cpp, and SGLang detection no longer falls through to vLLM when /metrics is off.
Also
  • –needle runs a needle-in-a-haystack retrieval sweep across context lengths and depths.
  • The suite runs on Windows again; two of the failures it found were real product bugs in timing.
  • New docs/troubleshooting.md and docs/cli-reference.md, and the README is a third of its old length.
Compatibility
The graders and the thinking-mode token ceiling both changed, so scores from 2.7.0 are not comparable to 2.6.0. Rerun your baselines. The ceiling in use is printed under Run Context, and leaderboard keeps runs from different conditions in separate cohorts rather than one ranking.
Full changelog: tool-eval-bench/CHANGELOG.md at main · SeraphimSerapis/tool-eval-bench · GitHub
1st run on 2.7.0 with Qwen3.8-Flash-Next and settings
tool-eval-bench --base-url http://0.0.0.0:8000  --seed 42 --backend vllm --perf --spec-bench
I just wanted to say that this tool has been instrumental in helping me diagnose and measure my processes when healing the Shared Experts in the models I’ve been working with, specifically with the 2.7.0 version.
MTP was always hard to measure but --spec-bench is very accurate and straight forward! Once again, thanks @serapis !
Messages like this one make my day! Glad it is helpful! ❤️
tool-eval-bench 2.8.0 is out
A few changes worth knowing about if you’re comparing local models and serving setups:
Decision-model support. If you’re experimenting with models for routing, triage, or invoice approval, you can now measure whether they choose the right option and how often
they’re confidently wrong. The benchmark runs 400 Typed Decisions cases through llama.cpp’s /v1/systemone endpoint.
With a decision-model server running:
tool-eval-bench plugin decision --base-url http://localhost:8084
You can also use a decision model to audit selected answers from your tool-calling runs. Disagreements are flagged for review; official scores stay unchanged.
Broader engine support. TabbyAPI, Strata, and TensorFold are now supported. Detection distinguishes servers that previously looked like llama.cpp, and context-window and
quantization reporting are more accurate. Your reports should better reflect the setup you’re actually testing.
More Hard Mode. Nine new scenarios bring the optional suite to 28. They test things like releasing held funds after a failed payment, respecting tenant boundaries, and
redacting a document copy without damaging the original. --hardmode now runs 97 scenarios; the default stays at 69.
Fewer misleading results. Graders catch more fabricated success claims, such as saying a refund succeeded when it didn’t. Malformed server responses count as infrastructure
failures rather than model mistakes. Injected failures no longer apply a tool’s side effects before the model retries it.
To update:
Release notes and downloads
Please rerun your baselines. Grading and comparison rules changed, so 2.8.0 scores aren’t directly comparable with earlier releases.
EDIT: To make things easier – now also available via pip: tool-eval-bench on PyPI
