Allright! This is cool! :)
I’m upgrading now since next week I have upcoming work so I can lock-in the versions before “breaking” any new model that might be about to come out!
I’m glad you like it!
That is a correct assumption on the speed reasons :-) I’m using a lightly modified version of this one with azampatt INT4 checkpoint.
Perfect and what I learned:
On the left side, you can see the highlighted one this is the search finding the Speculative run file associated with the full run directly above it. I deleted a few before I check the file dates-file name association.
So maybe fix these speculative listings to show something besides unknown, on include them in the known completed run scores ( when found ) so they can show up in the comparable results as well.
Thanks for digging into that, David! Those “unknown” rows were your --spec-bench results. One command stores a separate run for each mode, and the web UI was drawing all of them as tool-call runs. That’s where the empty ring, “unknown” and 0/0/0 came from.
That’s fixed on main: feat(web): show each run type's measurements and link runs of one session by SeraphimSerapis · Pull Request #329 · SeraphimSerapis/tool-eval-bench · GitHub
Hope it works for you.
Today is a great day! I’ve seen TC-68 pass for the first time!
● TC-68 Schema Violation Resistance ✅ PASS 2/2 9.5s ttft=1,748ms
Produced schema-compliant JSON without the forbidden extra fields,
despite the user requesting them.
Model: Qwen3.8-Flash-Next-EXL3-4.05-mlx:xhigh
I have to celebrate somehow! 🥳
