Invalid argument: Invalid JPEG data or crop window, data size 786432
• Hardware RTX 2060
• Network Type (Detectnet_v2)
• TLT Version (4.0.0)
I am trying to train Detectnet v2 with the following specs file:
random_seed: 42
dataset_config {
  data_sources {
    tfrecords_path: "/workspace/tao-experiments/data/tfrecords/kitti_trainval/*"
    image_directory_path: "/workspace/tao-experiments/data/train"
  image_extension: "jpg"
  target_class_mapping {
    key: "sedan"
    value: "sedan"
    key: "midtruck"
    value: "midtruck"
    key: "motorbike"
    value: "motorbike"
    key: "threewheeler"
    value: "threewheeler"
    key: "bicycle"
    value: "bicycle"
    key: "minibus"
    value: "minibus"
    key: "lighttruck"
    value: "lighttruck"
    key: "microbus"
    value: "microbus"
    key: "bigbus"
    value: "bigbus"
    key: "heavytruck"
    value: "heavytruck"
    key: "utility"
    value: "utility"
    key: "nmt"
    value: "nmt"
    key: "person"
    value: "person"
  validation_fold: 0
augmentation_config {
  preprocessing {
    output_image_width: 1248
    output_image_height: 384
    min_bbox_width: 1.0
    min_bbox_height: 1.0
    output_image_channel: 3
  spatial_augmentation {
    hflip_probability: 0.5
    zoom_min: 1.0
    zoom_max: 1.0
    translate_max_x: 8.0
    translate_max_y: 8.0
  color_augmentation {
    hue_rotation_max: 25.0
    saturation_shift_max: 0.20000000298
    contrast_scale_max: 0.10000000149
    contrast_center: 0.5
postprocessing_config {
    target_class_config {
        key: "sedan"
        value {
            clustering_config {
                clustering_algorithm: DBSCAN
                dbscan_confidence_threshold: 0.9
                coverage_threshold: 0.00499999988824
                dbscan_eps: 0.20000000298
                dbscan_min_samples: 0.0500000007451
                minimum_bounding_box_height: 20
        key: "midtruck"
        value {
            clustering_config {
        key: "motorbike"
        value {
            clustering_config {
        key: "heavytruck"
        value {
            clustering_config {
        key: "microbus"
        value {
            clustering_config {
        key: "bicycle"
        value {
            clustering_config {
        key: "threewheeler"
        value {
            clustering_config {
        key: "lighttruck"
        value {
            clustering_config {
        key: "minibus"
        value {
            clustering_config {
        key: "bigbus"
        value {
            clustering_config {
        key: "utility"
        value {
            clustering_config {
        key: "nmt"
        value {
            clustering_config {
        key: "person"
        value {
            clustering_config {
model_config {
  pretrained_model_file: "/workspace/tao-experiments/detectnet_v2/pretrained_resnet18/pretrained_detectnet_v2_vresnet18/resnet18.hdf5"
  num_layers: 18
  use_batch_norm: true
  objective_set {
    bbox {
      scale: 35.0
      offset: 0.5
    cov {
  arch: "resnet"
evaluation_config {
  validation_period_during_training: 10
  first_validation_epoch: 5
  minimum_detection_ground_truth_overlap {
    key: "sedan"
    value: 0.5
    key: "midtruck"
    value: 0.5
    key: "motorbike"
    value: 0.5
    key: "threewheeler"
    value: 0.5
    key: "bicycle"
    value: 0.5
    key: "minibus"
    value: 0.5
    key: "lighttruck"
    value: 0.5
    key: "microbus"
    value: 0.5
    key: "bigbus"
    value: 0.5
    key: "heavytruck"
    value: 0.5
    key: "utility"
    value: 0.5
    key: "nmt"
    value: 0.5
    key: "person"
    value: 0.5
  evaluation_box_config {
    key: "microbus"
    value {
      minimum_height: 20
      maximum_height: 9999
      minimum_width: 10
      maximum_width: 9999
    key: "heavytruck"
    value {
      minimum_height: 20
      minimum_width: 10
      maximum_width: 9999
    key: "motorbike"
    value {
      minimum_height: 20
      minimum_width: 10
      maximum_width: 9999
    key: "midtruck"
    value {
      minimum_height: 20
      minimum_width: 10
      maximum_width: 9999
    key: "bicycle"
    value {
      minimum_height: 20
      minimum_width: 10
      maximum_width: 9999
    key: "threewheeler"
    value {
      minimum_height: 20
      minimum_width: 10
      maximum_width: 9999
    key: "lighttruck"
    value {
      minimum_height: 20
      minimum_width: 10
      maximum_width: 9999
    key: "minibus"
    value {
      minimum_height: 20
      minimum_width: 10
      maximum_width: 9999
    key: "bigbus"
    value {
      minimum_height: 20
      minimum_width: 10
      maximum_width: 9999
    key: "sedan"
    value {
      minimum_height: 20
      minimum_width: 10
      maximum_width: 9999
    key: "utility"
    value {
      minimum_height: 20
      minimum_width: 10
      maximum_width: 9999
    key: "nmt"
    value {
      minimum_height: 20
      minimum_width: 10
      maximum_width: 9999
    key: "person"
    value {
      minimum_height: 20
      minimum_width: 10
      maximum_width: 9999
  average_precision_mode: INTEGRATE
cost_function_config {
  target_classes {
    class_weight: 1.0
    coverage_foreground_weight: 0.0500000007451
    objectives {
      initial_weight: 1.0
      weight_target: 1.0
    objectives {
      initial_weight: 10.0
      weight_target: 10.0
  target_classes {
    class_weight: 1.0
    objectives {
      initial_weight: 1.0
      weight_target: 1.0
    objectives {
      weight_target: 10.0
  target_classes {
    class_weight: 1.0
    objectives {
      initial_weight: 1.0
      weight_target: 1.0
    objectives {
      weight_target: 10.0
  target_classes {
    class_weight: 1.0
    objectives {
      initial_weight: 1.0
      weight_target: 1.0
    objectives {
      weight_target: 10.0
  target_classes {
    class_weight: 1.0
    objectives {
      initial_weight: 1.0
      weight_target: 1.0
    objectives {
      weight_target: 10.0
  target_classes {
    class_weight: 1.0
    objectives {
      initial_weight: 1.0
      weight_target: 1.0
    objectives {
      weight_target: 10.0
  target_classes {
    class_weight: 1.0
    objectives {
      initial_weight: 1.0
      weight_target: 1.0
    objectives {
      weight_target: 10.0
  target_classes {
    class_weight: 1.0
    objectives {
      initial_weight: 1.0
      weight_target: 1.0
    objectives {
      weight_target: 10.0
  target_classes {
    class_weight: 1.0
    objectives {
      initial_weight: 1.0
      weight_target: 1.0
    objectives {
      weight_target: 10.0
  target_classes {
    class_weight: 1.0
    objectives {
      initial_weight: 1.0
      weight_target: 1.0
    objectives {
      weight_target: 10.0
  target_classes {
    class_weight: 1.0
    objectives {
      initial_weight: 1.0
      weight_target: 1.0
    objectives {
      weight_target: 10.0
  target_classes {
    class_weight: 1.0
    objectives {
      initial_weight: 1.0
      weight_target: 1.0
    objectives {
      weight_target: 10.0
  target_classes {
    class_weight: 1.0
    objectives {
      initial_weight: 1.0
      weight_target: 1.0
    objectives {
      weight_target: 10.0
  enable_autoweighting: true
  max_objective_weight: 0.999899983406
  min_objective_weight: 9.99999974738e-05
training_config {
  batch_size_per_gpu: 8
  num_epochs: 120
  learning_rate {
    soft_start_annealing_schedule {
      min_learning_rate: 5e-06
      max_learning_rate: 5e-04
      soft_start: 0.10000000149
      annealing: 0.699999988079
  regularizer {
    type: L1
    weight: 3.00000002618e-09
  optimizer {
    adam {
      epsilon: 9.99999993923e-09
      beta1: 0.899999976158
      beta2: 0.999000012875
  cost_scaling {
    initial_exponent: 20.0
    increment: 0.005
    decrement: 1.0
  visualizer{
    enabled: true
    num_images: 3
    scalar_logging_frequency: 50
    infrequent_logging_frequency: 5
      key: "sedan"
      value: {
        coverage_threshold: 0.005
      key: "midtruck"
      value: {
      key: "motorbike"
      value: {
      key: "threewheeler"
      value: {
      key: "bicycle"
      value: {
      key: "minibus"
      value: {
      key: "lighttruck"
      value: {
      key: "microbus"
      value: {
      key: "bigbus"
      value: {
      key: "heavytruck"
      value: {
      key: "utility"
      value: {
      key: "nmt"
      value: {
      key: "person"
      value: {
    clearml_config{
      project: "TAO Toolkit ClearML Demo"
      task: "detectnet_v2_resnet18_clearml"
      tags: "detectnet_v2"
      tags: "training"
      tags: "resnet18"
      tags: "unpruned"
    wandb_config{
      project: "TAO Toolkit Wandb Demo"
      tags: "training"
      tags: "resnet18"
      tags: "unpruned"
  checkpoint_interval: 1
bbox_rasterizer_config {
    key: "sedan"
    value {
      cov_center_x: 0.5
      cov_center_y: 0.5
      cov_radius_x: 1.0
      cov_radius_y: 1.0
      bbox_min_radius: 1.0
    key: "midtruck"
    value {
      cov_center_x: 0.5
      cov_center_y: 0.5
      cov_radius_x: 1.0
      cov_radius_y: 1.0
    key: "motorbike"
    value {
      cov_center_x: 0.5
      cov_center_y: 0.5
      cov_radius_x: 1.0
      cov_radius_y: 1.0
    key: "threewheeler"
    value {
      cov_center_x: 0.5
      cov_center_y: 0.5
      cov_radius_x: 1.0
      cov_radius_y: 1.0
    key: "bicycle"
    value {
      cov_center_x: 0.5
      cov_center_y: 0.5
      cov_radius_x: 1.0
      cov_radius_y: 1.0
    key: "minibus"
    value {
      cov_center_x: 0.5
      cov_center_y: 0.5
      cov_radius_x: 1.0
      cov_radius_y: 1.0
    key: "lighttruck"
    value {
      cov_center_x: 0.5
      cov_center_y: 0.5
      cov_radius_x: 1.0
      cov_radius_y: 1.0
    key: "microbus"
    value {
      cov_center_x: 0.5
      cov_center_y: 0.5
      cov_radius_x: 1.0
      cov_radius_y: 1.0
    key: "bigbus"
    value {
      cov_center_x: 0.5
      cov_center_y: 0.5
      cov_radius_x: 1.0
      cov_radius_y: 1.0
    key: "heavytruck"
    value {
      cov_center_x: 0.5
      cov_center_y: 0.5
      cov_radius_x: 1.0
      cov_radius_y: 1.0
    key: "utility"
    value {
      cov_center_x: 0.5
      cov_center_y: 0.5
      cov_radius_x: 1.0
      cov_radius_y: 1.0
    key: "nmt"
    value {
      cov_center_x: 0.5
      cov_center_y: 0.5
      cov_radius_x: 1.0
      cov_radius_y: 1.0
    key: "person"
    value {
      cov_center_x: 0.5
      cov_center_y: 0.5
      cov_radius_x: 1.0
      cov_radius_y: 1.0
    deadzone_radius: 0.400000154972
But after first epoch, it returns the error:
INFO:tensorflow:epoch = 0.9673596746485292, learning_rate = 7.247637e-06, loss = 0.00015355347, step = 82776 (5.518 sec)
2023-03-02 17:39:51,154 [INFO] tensorflow: epoch = 0.9673596746485292, learning_rate = 7.247637e-06, loss = 0.00015355347, step = 82776 (5.518 sec)
INFO:tensorflow:epoch = 0.9675934041533732, learning_rate = 7.2482867e-06, loss = 0.0001721511, step = 82796 (5.522 sec)
2023-03-02 17:39:56,676 [INFO] tensorflow: epoch = 0.9675934041533732, learning_rate = 7.2482867e-06, loss = 0.0001721511, step = 82796 (5.522 sec)
2023-03-02 17:39:57,510 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 28.931
INFO:tensorflow:epoch = 0.9678271336582173, learning_rate = 7.2489365e-06, loss = 0.00016435228, step = 82816 (5.530 sec)
2023-03-02 17:40:02,206 [INFO] tensorflow: epoch = 0.9678271336582173, learning_rate = 7.2489365e-06, loss = 0.00016435228, step = 82816 (5.530 sec)
2023-03-02 17:40:04,421 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 28.943
INFO:tensorflow:epoch = 0.9680608631630614, learning_rate = 7.2495864e-06, loss = 0.00016470911, step = 82836 (5.530 sec)
2023-03-02 17:40:07,736 [INFO] tensorflow: epoch = 0.9680608631630614, learning_rate = 7.2495864e-06, loss = 0.00016470911, step = 82836 (5.530 sec)
2023-03-02 17:40:11,334 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 28.934
Input file read error
INFO:tensorflow:epoch = 0.9682945926679054, learning_rate = 7.250236e-06, loss = 0.00014266044, step = 82856 (5.533 sec)
2023-03-02 17:40:13,269 [INFO] tensorflow: epoch = 0.9682945926679054, learning_rate = 7.250236e-06, loss = 0.00014266044, step = 82856 (5.533 sec)
2023-03-02 17:40:15,236 [INFO] root: Saving trained model.
2023-03-02 17:40:16,195 [INFO] root: Model saved.
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1365, in _do_call
    return fn(*args)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1350, in _run_fn
    target_list, run_metadata)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1443, in _call_tf_sessionrun
    run_metadata)
tensorflow.python.framework.errors_impl.InvalidArgumentError: 2 root error(s) found.
  (0) Invalid argument: {{function_node __inference_Dataset_map__map_func_set_random_wrapper_5585}} Invalid JPEG data or crop window, data size 786432
	 [[{{node AssetLoader/DecodeJpeg}}]]
	 [[data_loader_out]]
  (1) Invalid argument: {{function_node __inference_Dataset_map__map_func_set_random_wrapper_5585}} Invalid JPEG data or crop window, data size 786432
	 [[data_loader_out]]
	 [[NotEqual_1/_5117]]
0 successful operations.
0 derived errors ignored.
During handling of the above exception, another exception occurred:
  File "</usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/scripts/train.py>", line 3, in <module>
  File "<frozen iva.detectnet_v2.scripts.train>", line 1022, in <module>
  File "<frozen iva.detectnet_v2.scripts.train>", line 1011, in <module>
  File "<decorator-gen-117>", line 2, in main
  File "<frozen iva.detectnet_v2.utilities.timer>", line 46, in wrapped_fn
  File "<frozen iva.detectnet_v2.scripts.train>", line 994, in main
  File "<frozen iva.detectnet_v2.scripts.train>", line 853, in run_experiment
  File "<frozen iva.detectnet_v2.scripts.train>", line 728, in train_gridbox
  File "<frozen iva.detectnet_v2.scripts.train>", line 200, in run_training_loop
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 754, in run
    run_metadata=run_metadata)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1360, in run
    raise six.reraise(*original_exc_info)
  File "/usr/local/lib/python3.6/dist-packages/six.py", line 696, in reraise
    raise value
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1345, in run
    return self._sess.run(*args, **kwargs)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1418, in run
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1176, in run
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 956, in run
    run_metadata_ptr)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1180, in _run
    feed_dict_tensor, options, run_metadata)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1359, in _do_run
    run_metadata)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1384, in _do_call
    raise type(e)(node_def, op, message)
  (0) Invalid argument:  Invalid JPEG data or crop window, data size 786432
	 [[data_loader_out]]
  (1) Invalid argument:  Invalid JPEG data or crop window, data size 786432
	 [[data_loader_out]]
Telemetry data couldn't be sent, but the command ran successfully.
[WARNING]: <urlopen error [Errno -2] Name or service not known>
Execution status: FAIL
2023-03-02 23:40:39,885 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
print('Model for each epoch:')
print('---------------------')
I have prepared the TFrecords with the following specs:
kitti_config {
  root_directory_path: "/workspace/tao-experiments/data/train"
  image_dir_name: "images"
  label_dir_name: "labels"
  image_extension: ".jpg"
  partition_mode: "random"
  num_partitions: 2
  val_split: 14
  num_shards: 10
I have manually checked the images and labels but found no corrupt images. Is there any way to check TFrecords data integrity?
My label files are formatted in KITTI annotation format like the following:
bicycle 0.0 0 0.0 1335.178955078125 596.6967163085938 1361.0630187988281 636.173641204834 0.0 0.0 0.0 0.0 0.0 0.0 0.0
Please help me resolve the issue.
Suggest you use bisection method to check which image does not work.
For example, you can select part of tfreocrds and train.
If works, then select another part of tfrecords and train.
I found the corrupt tfrecords file and excluded it. Now the training is running, but not converging:
{"epoch": 23, "max_epoch": 120, "time_per_epoch": "7:52:09.933331", "eta": "31 days, 19:20:03.533108", "date": "3/17/2023", "time": "8:6:4", "status": "RUNNING", "verbosity": "INFO", "categorical": {"average_precision": {"sedan": 0.0, "midtruck": 0.0, "motorbike": 0.0, "threewheeler": 0.0, "bicycle": 0.0, "minibus": 0.0, "lighttruck": 0.0, "microbus": 0.0, "bigbus": 0.0, "heavytruck": 0.0, "utility": 0.0, "nmt": 0.0, "person": 0.0}}, "graphical": {"loss": 5.01993440593651e-07, "learning_rate": 0.0004999999655410647}}
{"epoch": 24, "max_epoch": 120, "time_per_epoch": "6:08:00.679074", "eta": "24 days, 12:49:05.191063", "date": "3/17/2023", "time": "14:14:5", "status": "RUNNING", "verbosity": "INFO", "categorical": {"average_precision": {"sedan": 0.0, "midtruck": 0.0, "motorbike": 0.0, "threewheeler": 0.0, "bicycle": 0.0, "minibus": 0.0, "lighttruck": 0.0, "microbus": 0.0, "bigbus": 0.0, "heavytruck": 0.0, "utility": 0.0, "nmt": 0.0, "person": 0.0}}, "graphical": {"loss": 2.003043391596293e-06, "learning_rate": 0.0004999999655410647}}
What could possibly go wrong with my training specs?
What is the average resolution of your training images?
the average resolution of the images are 1920x1080. I have checked the annotations and the coordinates are are okey with the resolution.
So, please change to
output_image_width: 1920
output_image_height: 1088
More, if your training images have several kinds of resolution, please set
`enable_auto_resize: true"
My dataset images are mostly 1920x1080 resolution, but some of them are 1248x384. If I set output_image_width and height to 1920x1080 and enable_auto_resize, will the lower image resolutions be upscaled? Or the higher resolution images be downscaled?
Yes. enable_auto_resize is a flag to enable automatic resize during training.
Please set to 1920 x 1088.
See more info in DetectNet_v2 - NVIDIA Docs
