• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 5.1
• TensorRT Version 7.2
• NVIDIA GPU Driver Version (valid for GPU only) 460.80
• Issue Type( questions, new requirements, bugs) Bug
I am running trafficcamnet directly out of the 5.1-21.02-devel container using the included deepstream_app_source1_trafficcamnet.txt and config_infer_primary_trafficcamnet.txt. When I use the gie-kitti-output-dir option to save out the detection data, the confidence values for the detections are always -0.1. Example from my output:
car 0.0 0 0.0 654.666687 498.970581 802.666687 557.205872 0.0 0.0 0.0 0.0 0.0 0.0 0.0 -0.100000
person 0.0 0 0.0 290.666656 516.176453 310.666656 569.117615 0.0 0.0 0.0 0.0 0.0 0.0 0.0 -0.100000
road_sign 0.0 0 0.0 150.666672 477.794128 168.000000 501.617645 0.0 0.0 0.0 0.0 0.0 0.0 0.0 -0.100000
When running peoplenet under a similar configuration, I see valid confidence values from the detector output:
person 0.0 0 0.0 468.712311 239.408798 672.233765 643.830872 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.979707
person 0.0 0 0.0 0.060968 393.945251 170.399490 651.968201 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.964589
