Invalid configuration argument Kernels fail to work with big arrays
Hey,
I am trying a simple CUDA tutorial I found in this site. It is supposed to square all elements of an array.
The problem is this: the program works well with arrays of 100,000 and 200,000 items, but fails when N reaches bigger numbers. When N is bigger no calculation at all is done on the array, and I get an “Invalid configuration argument” when I execute my Kernel.
I suspect it is something to do with the block_size but I haven’t found the bug yet…
Here is the code:
#include <conio.h>
#include <stdio.h>
#include <cuda.h>
// Kernel that executes on the CUDA device
__global__ void square_array(float *a, int N)
  int idx = blockIdx.x * blockDim.x + threadIdx.x;
  if (idx<N) a[idx] = a[idx] * a[idx];
void checkCUDAError(const char *msg)
    cudaError_t err = cudaGetLastError();
    if( cudaSuccess != err)
        fprintf(stderr, "Cuda error: %s: %s.\n", msg,
                                  cudaGetErrorString( err) );
// main routine that executes on the host
int main(void)
	float *a_h, *a_d;  // Pointer to host & device arrays
	int N = 100000;  // Number of elements in arrays
	size_t size = N * sizeof(float);
	a_h = (float *)malloc(size);        // Allocate array on host
	cudaMalloc((void **) &a_d, size);   // Allocate array on device
	//Initialize host array and copy it to CUDA device
	for (int i=0; i<N; i++)
  a_h[i] = (float)i;
	cudaMemcpy(a_d, a_h, size, cudaMemcpyHostToDevice);
	// Do calculation on device:
	int block_size = 4;
	int n_blocks = N/block_size + (N%block_size == 0 ? 0:1);
	square_array <<< n_blocks, block_size >>> (a_d, N);
	// Check for any CUDA errors
	checkCUDAError("Kernel");
	// Retrieve result from device and store it in host array
	cudaMemcpy(a_h, a_d, sizeof(float)*N, cudaMemcpyDeviceToHost);
	checkCUDAError("memcpy");
	// Print results
	for (int i=0; i<1000; i++)
  printf("%d %f\n", i, a_h[i]);
	// Cleanup
	free(a_h); cudaFree(a_d);
	//Wait for key to exit
	printf("Press any key to exit...\n");
	getch();
	//Exit
	return(0);
Thanks in advance for your help.
You can’t have more than I think about 65000 blocks. And please read up in the programming guide, if you use only 4 threads per block you will have serious performance issues, 16 is the absolute reasonable minimum, normally it should not be less than 64.
Thank you!
