Invalid decryption. Unable to open file (file signature not found). The key used to load the model is incorrect
• Hardware (ubuntu18.04+rtx3060)
• Network Type (Faster_rcnn)
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
Configuration of the TLT Instance
dockers:
nvidia/tlt-streamanalytics:
docker_registry: nvcr.io
docker_tag: v3.0-py3
tasks:
1. augment
2. bpnet
3. classification
4. detectnet_v2
5. dssd
6. emotionnet
7. faster_rcnn
8. fpenet
9. gazenet
10. gesturenet
11. heartratenet
12. lprnet
13. mask_rcnn
14. multitask_classification
15. retinanet
16. ssd
17. unet
18. yolo_v3
19. yolo_v4
20. tlt-converter
nvidia/tlt-pytorch:
tasks:
1. speech_to_text
2. speech_to_text_citrinet
3. text_classification
4. question_answering
5. token_classification
6. intent_slot_classification
7. punctuation_and_capitalization
format_version: 1.0
tlt_version: 3.0
published_date: 04/16/2021
• Training spec file(If have, please share here)
Copyright (c) 2017-2020, NVIDIA CORPORATION. All rights reserved.
random_seed: 42
enc_key:‘tlt’
verbose: True
model_config {
input_image_config {
image_type: RGB
image_channel_order: ‘bgr’
size_height_width {
height: 384
width: 1248
image_channel_mean {
key: ‘b’
value: 103.939
key: ‘g’
value: 116.779
key: ‘r’
value: 123.68
image_scaling_factor: 1.0
max_objects_num_per_image: 100
arch: “resnet:18”
anchor_box_config {
scale: 64.0
scale: 128.0
scale: 256.0
ratio: 1.0
ratio: 0.5
ratio: 2.0
freeze_bn: True
freeze_blocks: 0
freeze_blocks: 1
roi_mini_batch: 256
rpn_stride: 16
use_bias: False
roi_pooling_config {
pool_size: 7
pool_size_2x: False
all_projections: True
use_pooling:False
dataset_config {
data_sources: {
tfrecords_path: “/workspace/tlt-experiments/data/tfrecords/kitti_trainval/kitti_trainval*”
image_directory_path: “/workspace/tlt-experiments/data/training”
image_extension: ‘png’
target_class_mapping {
key: ‘car’
value: ‘car’
key: ‘van’
value: ‘car’
key: ‘pedestrian’
value: ‘person’
key: ‘person_sitting’
value: ‘person’
key: ‘cyclist’
value: ‘cyclist’
validation_fold: 0
augmentation_config {
preprocessing {
output_image_width: 1248
output_image_height: 384
output_image_channel: 3
min_bbox_width: 1.0
min_bbox_height: 1.0
enable_auto_resize: True
spatial_augmentation {
hflip_probability: 0.5
vflip_probability: 0.0
zoom_min: 1.0
zoom_max: 1.0
translate_max_x: 0
translate_max_y: 0
color_augmentation {
hue_rotation_max: 0.0
saturation_shift_max: 0.0
contrast_scale_max: 0.0
contrast_center: 0.5
training_config {
enable_augmentation: True
enable_qat: False
batch_size_per_gpu: 8
num_epochs: 12
pretrained_weights: “/workspace/tlt-experiments/faster_rcnn/resnet_18.hdf5”
#resume_from_model: “/workspace/tlt-experiments/faster_rcnn/frcnn_kitti_resnet18.epoch2.tlt”
output_model: “/workspace/tlt-experiments/faster_rcnn/frcnn_kitti_resnet18.tlt”
rpn_min_overlap: 0.3
rpn_max_overlap: 0.7
classifier_min_overlap: 0.0
classifier_max_overlap: 0.5
gt_as_roi: False
std_scaling: 1.0
classifier_regr_std {
key: ‘x’
value: 10.0
key: ‘y’
value: 10.0
key: ‘w’
value: 5.0
key: ‘h’
value: 5.0
rpn_mini_batch: 256
rpn_pre_nms_top_N: 12000
rpn_nms_max_boxes: 2000
rpn_nms_overlap_threshold: 0.7
regularizer {
type: L2
weight: 1e-4
optimizer {
sgd {
lr: 0.02
momentum: 0.9
decay: 0.0
nesterov: False
learning_rate {
soft_start {
base_lr: 0.02
start_lr: 0.002
soft_start: 0.1
annealing_points: 0.8
annealing_points: 0.9
annealing_divider: 10.0
lambda_rpn_regr: 1.0
lambda_rpn_class: 1.0
lambda_cls_regr: 1.0
lambda_cls_class: 1.0
inference_config {
images_dir: ‘/workspace/tlt-experiments/data/testing/image_2’
model: ‘/workspace/tlt-experiments/faster_rcnn/frcnn_kitti_resnet18.epoch12.tlt’
batch_size: 1
detection_image_output_dir: ‘/workspace/tlt-experiments/faster_rcnn/inference_results_imgs’
labels_dump_dir: ‘/workspace/tlt-experiments/faster_rcnn/inference_dump_labels’
rpn_pre_nms_top_N: 6000
rpn_nms_max_boxes: 300
object_confidence_thres: 0.0001
bbox_visualize_threshold: 0.6
classifier_nms_max_boxes: 100
classifier_nms_overlap_threshold: 0.3
evaluation_config {
batch_size: 1
validation_period_during_training: 1
use_voc07_11point_metric:False
gt_matching_iou_threshold: 0.5
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
Using the official faster-rcnn example, there is no problem in the previous steps. In step 6, the key error is prompted. What is the reason?
According to your training spec, the key is set to “tlt”.
So, please set -k tlt in step 6.
Thinks!
my problem has been solved
