gabyx
June 16, 2011, 12:36pm
1
If I have
struct GPUAtomicCounter {
int *counter;
GPUAtomicCounter( void ) {
CHECK_CUDA( cudaMalloc( (void**)&counter,
sizeof(int) ) );
CHECK_CUDA( cudaMemset( counter, 0, sizeof(int) ) );
~GPUAtomicCounter( void ) {
cudaFree( counter );
template<typename PREC>
__global__ void branchTest_kernel(GPUAtomicCounter c){
int tx = threadIdx.x;
__host__ void test_kernelWrap(PREC * a){
dim3 threads(33);
dim3 blocks(1);
GPUAtomicCounter c;
//CHECK_CUDA( cudaMalloc( (void**)&c.counter, sizeof(int) ) );
//CHECK_CUDA( cudaMemset( c.counter, 0, sizeof(int) ) );
testsKernels::branchTest_kernel<<<blocks,threads>>>(c);
I get a invalide device pointer error after cuda kernel launch, kernel finished correctly, but I dont know whats wrong?
If I comment the destrcutor and constructor out, and initialize the GPUAtomiCounter outside (below definition of c) then the error disappears…?
Does anybody know whats the problem here?
Thanks?
Gabriel!
gabyx
2
If I have
int *counter;
sizeof(int) ) );
dim3 threads(33);
dim3 blocks(1);
GPUAtomicCounter c;
Thanks?
Gabriel!
I suppose the structure’s destructor is called at the end of the program when the context is already destroyed. I think it’s a bad idea to use destructor to deallocate device memory.
As for the allocation part, what you do appears weird to me. First, I see no need of using a separate structure. But if you just want some typechecking, it is fine because it makes no difference in terms of performance.
Second, normally we do memory allocation in this way:
struct GPUAtomicCounter{ int counter;};
main()
GPUAtomicCounter *dev_counters;
cudaMalloc((void**)&dev_counter, sizeof(GPUAtomicCounter) * numberOfCounters);
cudaMemset(dev_counter, 0, sizeof(GPUAtomicCounter) * numberOfCounters);
cudaFree(dev_counters);
