Invalid GPU in tracker depending on sink setup
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.3
• TensorRT Version from the container
• NVIDIA GPU Driver Version (valid for GPU only) 535
• Issue Type( questions, new requirements, bugs) bug
Hi there,
I see similar issue reported a few times but with no thorough follow up.
Myself and colleagues have recently spent a lot of time trying to debug the following error
GPUassert: invalid device ordinal src/modules/NvMultiObjectTracker/context.cpp 61
We observed it even though gpu-id was set to the same value in the config file where applicabble but also even if the gpu-id was the default 0 and the container had only one gpu available to it.
As of now it appears to us that this error usually appears when no sink is enabled in the deepstream app config file, but probably there are other situations that trigger it. We observed that with deepstream-app as well as with test5 app. Unfortunately, we are not able to debug the tracker any deeper.
Is this something that you are aware of and is it documented anywhere? Could the community know if there are other config cases that we should avoid?
I received the same issue before. But the user fixed by themself. Please refer: Invalid device ordinal in nvtracker - #3 by kesong
I saw that post before, but as I said, I observed this error even when gpu ids were set to the same (and correct) value and I don’t use any non-standard plugin that would affect cudaSetDevice. The user in the post that you linked also suggests that there is something external to tracker that sets gpu id and negatively affects the tracker
