Jetson Xavier
• DeepStream Version
6.0
4.6.3
• TensorRT Version
8.2.1
I clone into deepstream/deepstream/sources folder
git clone GitHub - NVIDIA-AI-IOT/deepstream_tao_apps: Sample apps to demonstrate how to deploy models trained with TAO on DeepStream
follow README for downloading models.
sudo make bodypose2D app and gesture app
I had to generate engine files for bodypose2D with tao-converter to get it to work. Used the following command:
sudo ./tao-converter -e /opt/nvidia/deepstream/deepstream/sources/deepstream_tao_apps/models/bodypose2d/model.etlt_b32_gpu0_fp16.engine -p input_1:0,1x288x384x3,1x288x384x3,32x288x384x3 -t fp16 -k nvidia_tlt -m 1 nvidia_tlt /opt/nvidia/deepstream/deepstream/sources/deepstream_tao_apps/models/bodypose2d/model.etlt
Then running bodypose2D app works fine. Was even able to write my own custom app using the basic outline of this app.
Now tried to run the gesture app and I get:
Decodebin child added: source
Decodebin child added: decodebin0
Running...
Decodebin child added: nvjpegdec0
In cb_newpad
###Decodebin pick nvidia decoder plugin.
terminate called after throwing an instance of 'std::runtime_error'
what(): invalid input pafmap dimension.
Aborted (core dumped)
After some troubleshooting, the pafmap dimensions are:
c: 36, h: 48, w:19
and heatmap dims are:
c: 144, h: 192, w:38
The app fails at line 433:
bodypose2Dposepost->execute(output, tempPafmap, tempHeatmap, post_w, post_h);
