Hello Everybody!
I am trying to write a work efficient parallel scan based on http://http.developer.nvidia.com/GPUGems3/gpugems3_ch39.html
I use a 16 element long array, containing only 1-s. It is an int list. The algorithm in gems have two phases, an up-sweep, and a down-sweep. Up-sweep works fine. Down-sweep stuck on the
temporary = shared_memory_ls[ai];
line. I used cuda-gdb and found out, that there are some invalid memory read, so I used memcheck. It says:
========= Invalid __shared__ read of size 4
========= at 0x00000b70 in /home/hooger/Dokumentumok/prog/c/cuda_test.cu:49:exclusive_scan(int const *, int*, int)
========= by thread (3,0,0) in block (0,0,0)
========= Address 0x000000dc is out of bounds
and a bunch of host_backtrace. It happens for threads from (2,0,0) to (7,0,0).
I use Debian Linux current version (as of today), with cuda 6 and nvidia driver 340. These are the stable versions, so I give it a really low probability, that it’s a driver bug.
lspci |grep VGA
01:00.0 VGA compatible controller: NVIDIA Corporation GF116 [GeForce GTS 450 Rev. 2] (rev a1)
Minimal example, producing the error:
#include <iostream>
#define LENGTH 16 // set the length of the array
__global__ void true_false(int* list, int len)
int idx = blockIdx.x * blockDim.x + threadIdx.x;
while(idx < len)
list[idx] = 1;
idx += gridDim.x * blockDim.x;
__global__ void exclusive_scan(const int* input, int* output, int len)
extern __shared__ int shared_memory_ls[];
int idx = blockDim.x * blockIdx.x + threadIdx.x;
int offset = 1;
int ai=0, bi=0,temporary=0;
shared_memory_ls[2 * idx] = input[2 * idx]; //A
shared_memory_ls[2 * idx + 1] = input[2 * idx + 1]; //A
for(int d = (len / 2); d > 0; d /= 2)
__syncthreads();
if(idx < d)
ai = offset * (2 * idx + 1) - 1; // B
bi = offset * (2 * idx + 2) - 1; // B
shared_memory_ls[bi] += shared_memory_ls[ai];
offset *= 2;
if (idx == 0)
shared_memory_ls[len - 1] = 0;
} // C
for(int d = 1; d < 2; d *= 2) /*It should be d<len, however it produceses the error and makes debugging easier */
offset /= 2;
__syncthreads();
if(idx < d);
ai = offset * (2 * idx + 1) - 1; // D
bi = offset * (2 * idx + 2) - 1; // D
shared_memory_ls[ai] = shared_memory_ls[bi];
shared_memory_ls[bi] += temporary;
__syncthreads();
output[2 * idx] = shared_memory_ls[2 * idx]; // E
output[2 * idx + 1] = shared_memory_ls[2 * idx + 1]; // E
int main()
cudaError_t errMsg;
int* host_ls;
int* device_ls_in;
int* device_ls_out;
host_ls = new int[LENGTH];
cudaMalloc((void**)&device_ls_in, sizeof(int) * LENGTH);
cudaMalloc((void**)&device_ls_out, sizeof(int) * LENGTH);
for(int i = 0; i<LENGTH; ++i)
host_ls[i] = 1;
cudaMemcpy(device_ls_in, host_ls, sizeof(int) * LENGTH, cudaMemcpyHostToDevice);
exclusive_scan<<<1, LENGTH/2, sizeof(int)*LENGTH>>>(device_ls_in, device_ls_out, LENGTH);
errMsg = cudaMemcpy(host_ls, device_ls_out, sizeof(int) * LENGTH, cudaMemcpyDeviceToHost);
if(errMsg)
std::cout << cudaGetErrorString(errMsg) << std::endl;
std::cout << host_ls[i] << ", ";
std::cout << std::endl;
errMsg = cudaFree(device_ls_in);
errMsg = cudaFree(device_ls_out);
delete[] host_ls;
return 0;
Both cudaFree produces the same error as the cudaMemcpy on line 76. Running the code on an 8 long array produces the excpected result with no errors (change line 2 and line 40 according to the comments to reproduce).
Any idea what am I doing wrong?
