Invalid ROS_IP (port should not be included)
Hey Guys,
I am currently walking through the ROS Tutorial and keep getting error about my ROS_IP stating that “port should not be included” when running roscore. I was able to bypass this using
export ROS_IP=MY_IP_ADDRESS
export ROS_MASTER_URI=http://$ROS_IP:11311/
I am now working on the turtlesim portion of the tutorial but cannot make the turtle move with my keyboard. I did verify that the terminal running the turtlesim_teleop_key was active.
I am positive that the issue is the ROS_IP in the ./bashrc. (Connected via WiFi)
Any suggestions on what the issue could be?
Thanks in advance.
