Hello! I am trying to flash TX2 NX with custom Auvidea board and I’m having issues with reading board information, what can I do here?
00:26:06 DEBUG: Flash Jetson TX2 - flash: using adapter to install NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2_TARGETS to /home/matiss/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_TX2_TARGETS
00:26:06 INFO: Flash Jetson TX2 - flash: change working directory to /home/matiss/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra
00:26:06 INFO: Flash Jetson TX2 - flash: sudo ./nvautoflash.sh
00:26:06 INFO: Flash Jetson TX2 - flash: *** Checking ONLINE mode ... OK.
00:26:06 INFO: Flash Jetson TX2 - flash: *** Checking target board connection ... 1 connections found.
00:26:08 INFO: Flash Jetson TX2 - flash: *** Reading ECID ... FUSELEVEL=fuselevel_production hwchipid=0x18 bootauth=NS
00:26:08 INFO: Flash Jetson TX2 - flash: *** Reading EEPROM ... "/home/matiss/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py" --chip 0x18 --applet "/home/matiss/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin; dump eeprom baseinfo bbd.bin; reboot recovery"
00:26:08 INFO: Flash Jetson TX2 - flash: [ 0.0049 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm /home/matiss/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
00:26:08 INFO: Flash Jetson TX2 - flash: [ 0.0092 ] Assuming zero filled SBK key
00:26:08 INFO: Flash Jetson TX2 - flash: [ 0.0217 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
00:26:08 INFO: Flash Jetson TX2 - flash: [ 0.0256 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml --skipuid
00:26:08 INFO: Flash Jetson TX2 - flash: [ 0.0262 ] RCM version 0X180001
00:26:11 INFO: Flash Jetson TX2 - flash: [ 2.1704 ] tegrarcm_v2 --isapplet
00:26:11 INFO: Flash Jetson TX2 - flash: [ 2.4393 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/matiss/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
00:26:11 INFO: Flash Jetson TX2 - flash: [ 2.4420 ] Applet version 01.00.0000
00:26:11 INFO: Flash Jetson TX2 - flash: [ 2.5877 ] Saved platform info in /home/matiss/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
00:26:11 INFO: Flash Jetson TX2 - flash: [ 2.7415 ] RCM 0 is saved as rcm_0.rcm
00:26:11 INFO: Flash Jetson TX2 - flash: [ 2.7488 ] Assuming zero filled SBK key
00:26:16 INFO: Flash Jetson TX2 - flash: [ 2.7713 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml
00:26:18 INFO: Flash Jetson TX2 - flash: [ 9.1270 ] tegrarcm_v2 --isapplet
00:26:18 INFO: Flash Jetson TX2 - flash: [ 9.5141 ] Applet version 01.00.0000
00:26:18 INFO: Flash Jetson TX2 - flash: UnicodeDecodeError: 'utf-8' codec can't decode byte 0xa4 in position 17: invalid start byte
00:26:18 INFO: Flash Jetson TX2 - flash: --- Error: Reading board information failed.
00:26:18 ERROR: Flash Jetson TX2 - flash: command terminated with error
