Hello! I am trying to flash TXi with custom board and I’m having issues with reading board information, what can I do here?
15:37:12 INFO: command finished successfully
15:37:12 DEBUG: running command < true >
15:37:12 DEBUG: Flash Jetson TX2 - flash: using adapter to install NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2_TARGETS to /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.1_Linux_JETSON_TX2_TARGETS
15:37:12 INFO: Flash Jetson TX2 - flash: change working directory to /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.1_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra
15:37:12 INFO: Flash Jetson TX2 - flash: exec_command: /tmp/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh
15:37:12 INFO: Flash Jetson TX2 - flash: sudo ./nvsdkmanager_flash.sh
15:37:12 INFO: Flash Jetson TX2 - flash: Defaulting to autoflash
15:37:12 INFO: Flash Jetson TX2 - flash: *** Checking ONLINE mode ... OK.
15:37:12 INFO: Flash Jetson TX2 - flash: *** Checking target board connection ... 1 connections found.
15:37:13 INFO: Flash Jetson TX2 - flash: *** Reading ECID ... FUSELEVEL=fuselevel_production hwchipid=0x18 bootauth=NS
15:37:13 INFO: Flash Jetson TX2 - flash: *** Reading EEPROM ... "/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.1_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py" --chip 0x18 --applet "/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.1_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin; dump eeprom baseinfo bbd.bin; reboot recovery"
15:37:14 INFO: Flash Jetson TX2 - flash: [ 0.0179 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.1_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
15:37:14 INFO: Flash Jetson TX2 - flash: [ 0.0361 ] Assuming zero filled SBK key
15:37:14 INFO: Flash Jetson TX2 - flash: [ 0.0515 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
15:37:14 INFO: Flash Jetson TX2 - flash: [ 0.0556 ] RCM version 0X180001
15:37:16 INFO: Flash Jetson TX2 - flash: [ 2.1707 ] tegrarcm_v2 --isapplet
15:37:16 INFO: Flash Jetson TX2 - flash: [ 2.3151 ] Applet version 01.00.0000
15:37:16 INFO: Flash Jetson TX2 - flash: [ 2.4594 ] Saved platform info in /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.6.1_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
15:37:16 INFO: Flash Jetson TX2 - flash: [ 2.5986 ] RCM 0 is saved as rcm_0.rcm
15:37:16 INFO: Flash Jetson TX2 - flash: [ 2.6020 ] Assuming zero filled SBK key
15:37:16 INFO: Flash Jetson TX2 - flash: [ 2.6188 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
15:37:22 INFO: Flash Jetson TX2 - flash: [ 2.6219 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml
15:37:23 INFO: Flash Jetson TX2 - flash: [ 8.8743 ] tegrarcm_v2 --isapplet
15:37:23 INFO: Flash Jetson TX2 - flash: [ 9.1426 ] Applet version 01.00.0000
15:37:23 ERROR: Flash Jetson TX2 - flash: UnicodeDecodeError: 'utf-8' codec can't decode byte 0xa4 in position 17: invalid start byte
15:37:23 ERROR: Flash Jetson TX2 - flash: --- Error: Reading board information failed.
15:37:24 ERROR: Flash Jetson TX2 - flash: command terminated with error
15:37:24 SUMMARY: DateTime Target Setup - target: Depends on failed component
15:38:17 INFO: DeepStream - target: stopped downloading https://developer.nvidia.com/assets/deepstream/deepstream_6.0.1/deepstream_601_b11/deepstream-6.0_6.0.1-1_arm64.deb
