My cuda code can run very well, but I want to use the float-point version automicAdd()function in kernel function. As we know the floating-point version of atomicAdd() is only supported by devices of compute capability 2.x. So I change my project setting to :GPU Architecture(1) sm_20, GPU Architecture(2) sm_20. When I run my program there was an error said that Runtime API error: invalid texure reference.
Thank you, my device is GeForce 9300M GS, its computer capability is 1.1. It means I couldn’t use the float point version atomicAdd()function, is there any other solution can solve my problem?
