I found both the core driver and nvidia customized driver is available in SDk provided by tegra tx1 23.2 version.
Is the customized driver is sufficient for the device MPU9250 of vendor Invensense.? Also Is the customized driver is communicating to user space via sysfs entries like core driver or some other way.?
Hello, Sherin:
that device is not mounted in Jetson board. In current L4T release, that device is not supported.
Generally, there may be different driver implementations for same device, through different driver infrastructure.
For some sensors, it may use IIO, or just misc input device.
Hello, Sherin:
As I mentioned in last reply, different drivers come from different framework.
You can check the driver source code, select the desired driver and make your own user space program for your application.
I am using nvidia Jetson TX2 with carrier board auvedia J120 and 32.1 TX2 software
I got to know J120 has IMU(MPU-9250) and it is connected to spidev1.0 bus
I am able to test the IMU using test QT application and it was working properly but i want to capture the raw data from IMU (accelometer,gyro,magnetometer)
for that i found one sample application in the git given by nvidia but it was not working
when i build and run the sample application it was giving the following ouput
