Hello! I’m a begginer in CUDA and i have some problems with calculation of inverse matrix. I wrote some code (really bad, but simple), but it doesn’t works if matrix is larger than 6x6. Can somebody find a problem here?
Problem solved, topic can be deleted =)
Code was very-very bad.
Here is an old Intel tech note on computing the 6x6 inverse using SSE instructions that should give you a pretty useful starting point for doing the complete inverse on a thread-by-thread basis.
