involving cufft when(nx, ny, nz)=(225, 329, 1499), the result is error, but other is OK
I have involved the cufft library, but I find some error with it!
when (nx, ny, nz)=(225, 329, 1499), the result is error!
when nz=1499, the result is error at most.
but when (nx, ny, nz)=(210, 324, 1500),(210, 324, 1500), (210, 324, 1515), (500, 500, 1500), the result is OK.
when nz<800, the result is OK.
the follow is my involving cufft methods:
1. in place, padding method
2. 3d
3. the first involving forward R2C, the second involving INVERSE C2R.
the code as follows:
I used the Tesla K40m, the memroy is 12GB
My compile option is
nvcc -arch=compute_35 -code=sm_35 -o cufft_in_place cufft_in_place.cu -lcudart -lcufft
#include <iostream>
#include <malloc.h>
#include <cuda.h>
#include <cufft.h>
#include <cuda_runtime_api.h>
const int Z=2700;
const int M=700;
const int N=560;
using namespace std;
int main(){
    int Nh=(N/2+1);
    //float *B=(float*)malloc(sizeof(float)*Z*M*N);
    float *A=(float*)malloc(sizeof(float)*Z*M*2*Nh);
    for(int k=0; k<Z; k++)
        for(int i=0; i<M; i++)
            for(int j=0; j<N; j++){
                A[k*2*Nh*M+i*2*Nh+j]=(i*N+j+1);///(float)RAND_MAX;
    cout<<"raw data"<<endl;
    cout<<"A[0]= "<<A[0]<<endl;
    cout<<"A[100]= "<<A[100]<<endl;
    cout<<"A[1310]= "<<A[1310]<<endl;
    cout<<"A[2320]= "<<A[2320]<<endl;
    //for(int k=0; k<Z; k++)
    //    for(int i=0; i<M; i++){
    //        for(int j=0; j<2*Nh; j++)
    //            cout<<A[k*M*Nh*2+i*Nh*2+j]<<" ";
    //        cout<<endl;
    cufftComplex* A_dev;
    cufftReal *a_dev;
    //cudaMalloc((void**)&a_dev, sizeof(float)*Z*M*N);
    cudaMalloc((void**)&a_dev, sizeof(float)*Z*M*2*Nh);
    cudaMemcpy(a_dev, A, sizeof(float)*Z*M*2*Nh, cudaMemcpyHostToDevice);
    A_dev=(cufftComplex*)a_dev;
    cufftHandle plan_forward;
    cufftPlan3d(&plan_forward, Z, M, N, CUFFT_R2C);
    cufftExecR2C(plan_forward, a_dev, A_dev);
    cudaMemcpy(A, A_dev, sizeof(float)*Z*M*2*Nh, cudaMemcpyDeviceToHost);
    cout<<"inv forward"<<endl;
    //for(int i=0; i<M; i++){
    //        cout<<A[k*2*Nh*M+i*2*Nh+j]<<" ";
    //    cout<<endl;
    memset(A, 0, sizeof(float)*Z*M*2*Nh);
    cufftHandle plan_backward;
    cufftPlan3d(&plan_backward, Z, M, N, CUFFT_C2R);
    cufftExecC2R(plan_backward, A_dev, a_dev);
    cudaMemcpy(A, a_dev, sizeof(float)*Z*M*2*Nh, cudaMemcpyDeviceToHost);
    cout<<"inv backward"<<endl;
    cout<<"A[0]= "<<A[0]/((float)(Z*M*N))<<endl;
    cout<<"A[100]= "<<A[100]/((float)(Z*M*N))<<endl;
    cout<<"A[1310]= "<<A[1310]/((float)(Z*M*N))<<endl;
    cout<<"A[2320]= "<<A[2320]/((float)(Z*M*N))<<endl;
    //        cout<<A[k*2*Nh*M+i*2*Nh+j]/(float)(Z*M*N)<<" ";
    //    cout<<endl;
    free(A);
    cudaFree(a_dev);
    return 0;
why ? I really need help!
cufft_in_place.cu (2.37 KB)
Side-remark: Other than in case of life-threatening emergency, there is never a need to use more than one exclamation mark in sequence.
I assume you are aware that application of a forward followed by a backward FFT with CUFFT may differ from other FFT implementations by a scale factor based on dimensions, since CUFFT performs a non-normalized() FFT? [] I am not entirely sure that “non-normalized” is the right term, I do not normally deal with FFTs.
What CUDA version are you using? I wonder whether your problem could be related to this known issue by any chance:
https://developer.nvidia.com/cuda-downloads
Please Note: In CUDA 7.0, the cuFFT library has a known issue that can lead to incorrect results for certain inputs sizes less than or equal to 1920 in any dimension when cufftSetStream() is passed a non-blocking stream (e.g., one created using the cudaStreamNonBlocking flag of the CUDA Runtime API or the CU_STREAM_NON_BLOCKING flag of the CUDA Driver API).
I don’t see any calls to cufftSetStream() in your code, though. Exactly how does the error you mention manifest itself? Are there numerical inaccuracies? Are there NaNs in the output? If the former, how much difference is there between actual and expected results? What program is used to produce the reference results you compare to? Can you trust the reference?
Thanks for your side-remark!
My cuda version is 6.5.
when (nx, ny, nz)=(225, 329, 1499), the stdout is:
raw data
A[0]= 1
A[100]= 101
A[1310]= 1306
A[2320]= 2311
inv forward
A[0]= 1
A[100]= 101
A[1310]= 1306
A[2320]= 2311
inv backward
A[0]= 9.01197e-09
A[100]= 9.10209e-07
A[1310]= 1.17696e-05
A[2320]= 2.08267e-05
when (nx, ny, nz)=(210, 324, 1500), the stdout is
raw data
A[0]= 1
A[100]= 101
A[1310]= 1299
A[2320]= 2301
inv forward
A[0]= 3.47213e+12
A[100]= -5.10312e+07
A[1310]= 120.755
A[2320]= 26.1938
inv backward
A[0]= 1.00553
A[100]= 101.004
A[1310]= 1298.99
A[2320]= 2301
I think the (nx, ny, nz)=(225, 329, 1499) is wrong, and the (nx, ny, nz)=(210, 324, 1500) is correct.
Doesn’t this code give incorrect results for any odd value of N ?
No.
when (nx, ny, nz)=(210, 324, 799), the result is correct.
when (nx, ny, nz)=(218, 321, 99), the result is correct.
I find if the nz>800, most odd value of N is wrong .
For example, when (nx, ny, nz)=(218, 321, 1099), the result is wrong.
My code is the Attachments of #1.
