Please provide the following info (tick the boxes after creating this topic): Software Version
DRIVE OS 6.0.8.1
Target Operating System
Linux
Hardware Platform
Host Machine Version
This works:
INvSIPLCamera::Init() → INvSIPLCamera::Start() → INvSIPLCamera::Stop() → INvSIPLCamera::DeInit()
This does not work
INvSIPLCamera::Init() → INvSIPLCamera::Start() → INvSIPLCamera::Stop() → INvSIPLCamera::Start()
or
INvSIPLCamera::Init() → INvSIPLCamera::Start() → INvSIPLCamera::Stop() → INvSIPLCamera::Init()
Have you tried calling DeInit() before re-initializing with Init()? This might resolve the NVSIPL_STATUS_INVALID_STATE error.
If this doesn’t work, could you share the error messages you’re encountering when calling Start() or Init() after call Stop()? These details could help diagnose the problem and find a solution.
To get more detailed error messages from calls that return nvsipl::SIPLStatus, consider enabling additional logging through INvSIPLTrace. By adjusting the trace levels, you may be able to gather more specific information about the errors you’re encountering.
No, but I think that would defeat the purpose. The idea is to temporarily pause a camera. Init()->Start()->Stop()->DeInit()->Init()->Start() would be overkill even if it works.
I’ve confirmed with our team that Start() should not be used as a restart or resume function after Stop(). Similarly, Init() should not be used as a reinitialization function; it cannot be called again after Stop() or Deinit().
The standard sequence we enforce is:
GetInstance → Set Configs → Init → Register Resources → Start → Stop → Deinit
The only exceptions are the EnableLink() and DisableLink() APIs, which can pause and resume streaming on a per-pipeline basis. However, these exceptions depend heavily on the quality of the camera drivers, as they must properly enable and disable streams on the camera module.
