IO_PAGE_FAULT and then transmit queue timed out
hi,all
we encouter IO_PAGE_FAULT and then transmit queue timed out,and we find this guid.
Mellanox Interconnect Community.
we also had updated the mlx5 driver and firmware to the latest version,and sure the SR-IOV is enabled on the BIOS and iommu=pt is set on the Linux grub menu,but we still has the problem.
my question is:
1.SR-IOV is enabled on the BIOS,when use EN not then OFED ,is it enable this feature?
2.any other advice to fix this “IO_PAGE_FAULT” problem?
thks
I recall AMD platform has this kind of issue on old kernel. You can try use lasted kernel and try disable iommu.
Thanks a lot,we will take your advice. If there any bad effect when "“diable iommu”
should be not
