Iot mqtt demo not working
Hello I followed the tutorial on github (NVIDIA-Omniverse/iot-samples) but the iot sessions live mqtt data doesnt show in the usd composer (the models are not moving and all values in Raw USD Properties stay at zero)
Can you help me?
---- LOG MESSAGES —
(‘Main’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘Connection library (version 0x000b001400000000, protocol version 1.19) settings:’)
(‘Main’, ‘nucleus_connection’, LogLevel.VERBOSE, ’ Transfer settings:‘)
(‘Main’, ‘nucleus_connection’, LogLevel.VERBOSE, ’ contentBufferSize = 1073741824’)
(‘Main’, ‘nucleus_connection’, LogLevel.VERBOSE, ’ receiveBufferSize = 268435456’)
(‘Main’, ‘nucleus_connection’, LogLevel.VERBOSE, ’ transmitBufferSize = 1073741824’)
(‘Main’, ‘nucleus_connection’, LogLevel.VERBOSE, ’ maxTransferConnectionCount = 10’)
(‘Main’, ‘nucleus_connection’, LogLevel.VERBOSE, ’ parallelTransferChunkSize = 1048576’)
(‘Main’, ‘nucleus_connection’, LogLevel.VERBOSE, ’ lftContentBufferSize = 1073741824’)
(‘Main’, ‘nucleus_connection’, LogLevel.VERBOSE, ’ Log settings:‘)
(‘Main’, ‘nucleus_connection’, LogLevel.VERBOSE, ’ logFile = 1’)
(‘Main’, ‘nucleus_connection’, LogLevel.VERBOSE, ’ logTickStatistics = 0’)
(‘Main’, ‘nucleus_connection’, LogLevel.VERBOSE, ’ logIncomingMessages = 1’)
(‘Main’, ‘nucleus_connection’, LogLevel.VERBOSE, ’ logOutgoingMessages = 1’)
(‘Main’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘OmniTrace dll/so not loaded’)
(‘Main’, ‘provider_nucleus’, LogLevel.INFO, ‘Initialized Nucleus API v11.20-4c89d0de’)
(‘Main’, ‘core’, LogLevel.VERBOSE, ‘Request 1: copy(file:C:\Users\cemck\Documents\BA\Omniverse\iot-samples\content/ConveyorBelt_A08_PR_NVD_01 => omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01)’)
(‘Tick’, ‘discovery’, LogLevel.DEBUG, ‘Discovery(localhost): Starting’)
(‘Tick’, ‘discovery’, LogLevel.INFO, ‘Discovery(wss://localhost/omni/discovery): Searching for services’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘0000021DFB0A74A0 connecting to wss://localhost/omni/discovery’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘connecting to wss://localhost:443/omni/discovery’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘0000021DE77D16C0 not using mTLS since client certificate and private key were not provided’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘<< id=1 DiscoverySearch.find 0000021DFB28A168’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘<< id=2 DiscoverySearch.find 0000021DFB28A168’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘<< id=3 DiscoverySearch.find 0000021DFB28AB88’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘<< id=4 DiscoverySearch.find 0000021DFB28A168’)
(‘Tick’, ‘discovery’, LogLevel.INFO, ‘Discovery(ws://localhost/omni/discovery): Searching for services’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘0000021DFB0A6B40 connecting to ws://localhost/omni/discovery’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘connecting to ws://localhost:80/omni/discovery’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘<< id=1 DiscoverySearch.find 0000021DFB289AA8’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘<< id=4 DiscoverySearch.find 0000021DFB28AB88’)
(‘Tick’, ‘discovery’, LogLevel.INFO, ‘Discovery(ws://localhost:3333): Searching for services’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘0000021DFB0A6820 connecting to ws://localhost:3333’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘connecting to ws://localhost:3333/’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘<< id=1 DiscoverySearch.find 0000021DFB28AB88’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 1: Stat(file:/C:/Users/cemck/Documents/BA/Omniverse/iot-samples/content/ConveyorBelt_A08_PR_NVD_01) returned Ok’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘0000021DF99C9900 Upgraded to WebSocket’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘>> id=1 {“found”: true, “version”: 2, “service_interface”: {“origin”: “OmniAuth.idl.ts”, “name”: “Credentials”, “capabilities”: {“get_settings”: 0, “auth”: 2, “register”: 3, “reset”: 2}}, “transport”: {“name”: “sows”, “params”: “{"host": "127.0.0.1", "port": 3100}”, “meta”: {“marshaller”: “bs”, “serializer”: “json”, “ssl”: “false”}}, “meta”: {“deployment”: “external”, “version”: “1.5.2”, “login_url”: “http://:3180”}}#’)
(‘Tick’, ‘discovery’, LogLevel.INFO, ‘Discovery(ws://localhost:3333): Found Auth::Credentials service using transport ‘sows’ {“host”: “127.0.0.1”, “port”: 3100}’)
(‘Tick’, ‘discovery’, LogLevel.INFO, ‘Discovery(ws://localhost:3333): Found auth login_url http://
:3180’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘>> id=2 {“found”: true, “version”: 2, “service_interface”: {“origin”: “OmniAuth.idl.ts”, “name”: “Tokens”, “capabilities”: {“generate”: 2, “refresh”: 1, “invalidate”: 0, “subscribe”: 0, “create_api_token”: 2, “delete_api_token”: 0, “get_api_tokens”: 0, “auth_with_api_token”: 1}}, “transport”: {“name”: “sows”, “params”: “{"host": "127.0.0.1", "port": 3100}”, “meta”: {“marshaller”: “bs”, “serializer”: “json”, “ssl”: “false”}}, “meta”: {“deployment”: “external”, “version”: “1.5.2”, “login_url”: “http://:3180”}}#’)
(‘Tick’, ‘discovery’, LogLevel.DEBUG, ‘Discovery(ws://localhost:3333): Auth::Tokens found!’)
(‘Tick’, ‘discovery’, LogLevel.DEBUG, ‘Discovery(ws://localhost:3333): Auth::Tokens supports subscribe!’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘>> id=3 {“found”: true, “version”: 2, “service_interface”: {“origin”: “OmniAuth.idl.ts”, “name”: “DeviceFlow”, “capabilities”: {“authorize”: 0, “submit”: 0, “token”: 0}}, “transport”: {“name”: “sows”, “params”: “{"host": "127.0.0.1", "port": 3100}”, “meta”: {“marshaller”: “bs”, “serializer”: “json”, “ssl”: “false”}}, “meta”: {“deployment”: “external”, “version”: “1.5.2”, “login_url”: “http://
:3180”}}#’)
(‘Tick’, ‘discovery’, LogLevel.DEBUG, ‘Discovery(ws://localhost:3333): Auth::DeviceFlow found!’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘>> id=4 {“found”: true, “version”: 2, “service_interface”: {“origin”: “omni1.idl.ts”, “name”: “Connection”, “capabilities”: {“add_user_to_group”: 0, “auth”: 5, “authorize_token”: 4, “change_acl”: 0, “checkpoint_version”: 2, “copy”: 2, “copy2”: 2, “create”: 2, “create_asset”: 2, “create_asset_with_hash”: 2, “create_directory”: 1, “create_group”: 0, “create_object”: 2, “deep_copy_object_struct”: 0, “delete”: 0, “delete2”: 1, “get_acl”: 0, “get_acl_resolved”: 0, “get_acl_v2”: 0, “get_branches”: 1, “get_checkpoints”: 1, “get_group_users”: 0, “get_groups”: 0, “get_mount_info”: 0, “get_transaction_id”: 0, “get_user_groups”: 0, “get_users”: 0, “list”: 5, “list2”: 5, “lock”: 3, “mount”: 0, “ping”: 0, “read”: 2, “read_asset_resolved”: 0, “read_asset_version”: 0, “read_object_resolved”: 0, “read_object_version”: 0, “remove_group”: 0, “remove_user_from_group”: 0, “rename”: 2, “rename2”: 1, “rename_group”: 0, “replace_version”: 1, “service_resolve_acl”: 2, “service_subscribe_list”: 1, “set_acl_v2”: 0, “set_path_options”: 1, “set_path_options2”: 0, “set_user_agent”: 0, “stat2”: 2, “subscribe_list”: 4, “subscribe_read_asset”: 2, “subscribe_read_object”: 3, “subscribe_server_notifications”: 0, “unlock”: 2, “unmount”: 0, “update”: 1, “update_asset”: 2, “update_asset_with_hash”: 2, “update_object”: 2, “stop”: 0}}, “transport”: {“name”: “connlib”, “params”: “{\n "url": "ws://127.0.0.1:3009"\n}”, “meta”: {}}, “meta”: {“deployment”: “external”}}#’)
(‘Tick’, ‘discovery’, LogLevel.DEBUG, ‘Discovery(ws://localhost:3333): Api::Connection found!’)
(‘Tick’, ‘discovery’, LogLevel.INFO, ‘Discovery(ws://localhost:3333): Found Nucleus API ws://127.0.0.1:3009’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘ssl send error: 10057’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘0000021DF9CB7E30 Terminating connection (socket closed)’)
(‘Tick’, ‘discovery’, LogLevel.INFO, ‘Discovery(wss://localhost/omni/discovery): Auth::Credentials search failed: Connection is terminated’)
(‘Tick’, ‘discovery’, LogLevel.DEBUG, ‘Discovery(wss://localhost/omni/discovery): Auth::Tokens search failed: Connection is terminated’)
(‘Tick’, ‘discovery’, LogLevel.DEBUG, ‘Discovery(wss://localhost/omni/discovery): Auth::DeviceFlow search failed: Connection is terminated’)
(‘Tick’, ‘discovery’, LogLevel.DEBUG, ‘Discovery(wss://localhost/omni/discovery): Api::Connection search failed: Connection is terminated’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘0000021DF9CB7E30 Sending CLOSE (reason=1000)’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘receive error: 10057’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘0000021DF99C9340 Terminating connection (socket closed)’)
(‘Tick’, ‘discovery’, LogLevel.INFO, ‘Discovery(ws://localhost/omni/discovery): Auth::Credentials search failed: Connection is terminated’)
(‘Tick’, ‘discovery’, LogLevel.DEBUG, ‘Discovery(ws://localhost/omni/discovery): Auth::Tokens search failed: Connection is terminated’)
(‘Tick’, ‘discovery’, LogLevel.DEBUG, ‘Discovery(ws://localhost/omni/discovery): Auth::DeviceFlow search failed: Connection is terminated’)
(‘Tick’, ‘discovery’, LogLevel.DEBUG, ‘Discovery(ws://localhost/omni/discovery): Api::Connection search failed: Connection is terminated’)
(‘Tick’, ‘discovery’, LogLevel.DEBUG, ‘Discovery(localhost): Completed’)
(‘Tick’, ‘discovery’, LogLevel.DEBUG, ‘Discovery(localhost): Stopping’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘0000021DFB0A74A0 destroyed’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘0000021DFB0A6820 destroyed’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘0000021DF99C9900 Sending CLOSE (reason=1000)’)
(‘Tick’, ‘discovery’, LogLevel.DEBUG, ‘Discovery(localhost): Calling Callback’)
(‘Tick’, ‘provider_nucleus’, LogLevel.INFO, ‘Using username/password from environment variables for omniverse://localhost’)
(‘Tick’, ‘provider_nucleus’, LogLevel.DEBUG, ‘Starting’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘0000021DFB0A8120 connecting to ws://127.0.0.1:3100’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘connecting to ws://127.0.0.1:3100/’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘<< id=1 Credentials.auth 0000021DFB28AEE8’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘0000021DFB0A6B40 destroyed’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘0000021DF99C9340 Sending CLOSE (reason=1000)’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘>> id=1 {“status”: “OK”, “version”: 2, “access_token”: “eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9.eyJzdWIiOiJjZW1jayIsInByb2ZpbGUiOnsiZmlyc3RfbmFtZSI6IkNlbSIsImxhc3RfbmFtZSI6IkthcmEiLCJlbWFpbCI6ImNlbTE0M0Bob3RtYWlsLmRlIiwiYWRtaW4iOnRydWUsIm51Y2xldXNfcm8iOmZhbHNlLCJyZWFkb25seSI6ZmFsc2UsInByb3ZpZGVyIjoiSW50ZXJuYWwiLCJlbmFibGVkIjp0cnVlLCJhY3RpdmF0ZWQiOnRydWV9LCJqdGkiOiIzYjE3NjkxZDhlMTM0ZjlhOGI2NTlmOWQyY2Q1OWU2NSIsImlhdCI6MTcxNDg2NTA5NywiZXhwIjoxNzE0OTUxNDk3fQ.c55qJieNpBQh-RfHyQUDVCAD-8ARm1Yk1tqS9AX8P7OmbD9lKP0oCFWEKjP73GpRXnP2hO_UmZS4TZHzn1oOfA”, “refresh_token”: “eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9.eyJzdWIiOiJjZW1jayIsInByb2ZpbGUiOnsiZmlyc3RfbmFtZSI6IkNlbSIsImxhc3RfbmFtZSI6IkthcmEiLCJlbWFpbCI6ImNlbTE0M0Bob3RtYWlsLmRlIiwiYWRtaW4iOnRydWUsIm51Y2xldXNfcm8iOmZhbHNlLCJyZWFkb25seSI6ZmFsc2UsInByb3ZpZGVyIjoiSW50ZXJuYWwiLCJlbmFibGVkIjp0cnVlLCJhY3RpdmF0ZWQiOnRydWV9LCJqdGkiOiIxMDliOGZmMDU4NTE0MTA4YjRjZTg5YTFmOGFjMjIzZCIsImlhdCI6MTcxNDg2NTA5NywiZXhwIjoxNzE3NDU3MDk3fQ.viyOh18CH2N6FshI7edhepoASg1BzR6hmSe7lSgAD4qyLu5k-PicJuXbK5eXlDmbItO78JMsaT8cltTZ5CoVXg”, “username”: “cemck”, “profile”: {“first_name”: “Cem”, “last_name”: “Kara”, “email”: “cem143@hotmail.de”, “admin”: true, “provider”: “Internal”, “readonly”: false, “nucleus_ro”: false, “enabled”: true, “activated”: true}}#’)
(‘Tick’, ‘provider_nucleus’, LogLevel.INFO, ‘Auth: Retrieved token for user “cemck”’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘0000021DE6A95E70 connecting to ws://127.0.0.1:3009’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘connecting to ws://127.0.0.1:3009/’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘Created connection 0000021DFB33E1C0’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘<< {“client_capabilities”:{“add_user_to_group”:0,“auth”:5,“authorize_token”:4,“change_acl”:0,“checkpoint_version”:2,“copy”:2,“copy2”:2,“create”:2,“create_asset”:2,“create_asset_with_hash”:2,“create_directory”:1,“create_group”:0,“create_object”:2,“deep_copy_object_struct”:0,“delete”:0,“delete2”:1,“get_acl”:0,“get_acl_resolved”:0,“get_acl_v2”:0,“get_branches”:1,“get_checkpoints”:1,“get_group_users”:0,“get_groups”:0,“get_mount_info”:0,“get_transaction_id”:0,“get_user_groups”:0,“get_users”:0,“list”:5,“list2”:5,“lock”:3,“mount”:0,“ping”:0,“read”:2,“read_asset_resolved”:0,“read_asset_version”:0,“read_object_resolved”:0,“read_object_version”:0,“remove_group”:0,“remove_user_from_group”:0,“rename”:2,“rename2”:1,“rename_group”:0,“replace_version”:1,“service_resolve_acl”:2,“service_subscribe_list”:1,“set_acl_v2”:0,“set_path_options”:1,“set_path_options2”:0,“set_user_agent”:0,“stat2”:2,“subscribe_list”:4,“subscribe_read_asset”:2,“subscribe_read_object”:3,“subscribe_server_notifications”:0,“unlock”:2,“unmount”:0,“update”:1,“update_asset”:2,“update_asset_with_hash”:2,“update_object”:2},“command”:“authorize_token”,“id”:1,“token”:“eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9.eyJzdWIiOiJjZW1jayIsInByb2ZpbGUiOnsiZmlyc3RfbmFtZSI6IkNlbSIsImxhc3RfbmFtZSI6IkthcmEiLCJlbWFpbCI6ImNlbTE0M0Bob3RtYWlsLmRlIiwiYWRtaW4iOnRydWUsIm51Y2xldXNfcm8iOmZhbHNlLCJyZWFkb25seSI6ZmFsc2UsInByb3ZpZGVyIjoiSW50ZXJuYWwiLCJlbmFibGVkIjp0cnVlLCJhY3RpdmF0ZWQiOnRydWV9LCJqdGkiOiIzYjE3NjkxZDhlMTM0ZjlhOGI2NTlmOWQyY2Q1OWU2NSIsImlhdCI6MTcxNDg2NTA5NywiZXhwIjoxNzE0OTUxNDk3fQ.c55qJieNpBQh-RfHyQUDVCAD-8ARm1Yk1tqS9AX8P7OmbD9lKP0oCFWEKjP73GpRXnP2hO_UmZS4TZHzn1oOfA”,“version”:“1.19”}’)
(‘Tick’, ‘provider_nucleus’, LogLevel.DEBUG, ‘Stopping’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘0000021DFB0A8120 destroyed’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘0000021DF99C9340 Upgraded to WebSocket’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“OK”,“server_capabilities”:{“add_user_to_group”:0,“auth”:5,“authorize_token”:4,“change_acl”:0,“checkpoint_version”:2,“copy”:2,“copy2”:2,“create”:2,“create_asset”:2,“create_asset_with_hash”:2,“create_directory”:1,“create_group”:0,“create_object”:2,“deep_copy_object_struct”:0,“delete”:0,“delete2”:1,“get_acl”:0,“get_acl_resolved”:0,“get_acl_v2”:0,“get_branches”:1,“get_checkpoints”:1,“get_group_users”:0,“get_groups”:0,“get_mount_info”:0,“get_transaction_id”:0,“get_user_groups”:0,“get_users”:0,“list”:5,“list2”:5,“lock”:3,“mount”:0,“ping”:0,“read”:2,“read_asset_resolved”:0,“read_asset_version”:0,“read_object_resolved”:0,“read_object_version”:0,“remove_group”:0,“remove_user_from_group”:0,“rename”:2,“rename2”:1,“rename_group”:0,“replace_version”:1,“service_resolve_acl”:2,“service_subscribe_list”:1,“set_acl_v2”:0,“set_path_options”:1,“set_path_options2”:0,“set_user_agent”:0,“stat2”:2,“subscribe_list”:4,“subscribe_read_asset”:2,“subscribe_read_object”:3,“subscribe_server_notifications”:0,“unlock”:2,“unmount”:0,“update”:1,“update_asset”:2,“update_asset_with_hash”:2,“update_object”:2},“ts”:{“omni_server_out_ts”:13347694223645260},“version”:""1.14.37-0959a9e9" ",“username”:“cemck”,“token”:“EW5A2COG7VWAGBGZ”,“connection_id”:“YH8GRXD7Q0HMBC7G”,“connection_id_signature”:“f0352aa2a405bd3b18e9a4d12b3382444e331f55f558e2f93029fd5b83844ff0”,“max_chunk_size”:134217728,“lft_address”:"http://127.0.0.1:3030",“lft_threshold”:65536,“super_user”:true,“multipart_chunk_size”:5242880,“max_in_flight_requests”:0,“id”:1}’)
(‘Tick’, ‘provider_nucleus’, LogLevel.VERBOSE, ‘Connected to omniverse://localhost as cemck’)
(‘Tick’, ‘provider_nucleus’, LogLevel.VERBOSE, ‘Connection ID: YH8GRXD7Q0HMBC7G’)
(‘Tick’, ‘provider_nucleus’, LogLevel.INFO, ‘Server is running version 1.14.37-0959a9e9’)
(‘Tick’, ‘provider_nucleus’, LogLevel.VERBOSE, ‘LFT Enabled. Threshold=64 KB, Server=http://127.0.0.1:3030’)
(‘Tick’, ‘provider_nucleus’, LogLevel.VERBOSE, ‘Server supports { { “add_user_to_group”, 0 }, { “auth”, 5 }, { “authorize_token”, 4 }, { “change_acl”, 0 }, { “checkpoint_version”, 2 }, { “copy”, 2 }, { “copy2”, 2 }, { “create”, 2 }, { “create_asset”, 2 }, { “create_asset_with_hash”, 2 }, { “create_directory”, 1 }, { “create_group”, 0 }, { “create_object”, 2 }, { “deep_copy_object_struct”, 0 }, { “delete”, 0 }, { “delete2”, 1 }, { “get_acl”, 0 }, { “get_acl_resolved”, 0 }, { “get_acl_v2”, 0 }, { “get_branches”, 1 }, { “get_checkpoints”, 1 }, { “get_group_users”, 0 }, { “get_groups”, 0 }, { “get_mount_info”, 0 }, { “get_transaction_id”, 0 }, { “get_user_groups”, 0 }, { “get_users”, 0 }, { “list”, 5 }, { “list2”, 5 }, { “lock”, 3 }, { “mount”, 0 }, { “ping”, 0 }, { “read”, 2 }, { “read_asset_resolved”, 0 }, { “read_asset_version”, 0 }, { “read_object_resolved”, 0 }, { “read_object_version”, 0 }, { “remove_group”, 0 }, { “remove_user_from_group”, 0 }, { “rename”, 2 }, { “rename2”, 1 }, { “rename_group”, 0 }, { “replace_version”, 1 }, { “service_resolve_acl”, 2 }, { “service_subscribe_list”, 1 }, { “set_acl_v2”, 0 }, { “set_path_options”, 1 }, { “set_path_options2”, 0 }, { “set_user_agent”, 0 }, { “stat2”, 2 }, { “subscribe_list”, 4 }, { “subscribe_read_asset”, 2 }, { “subscribe_read_object”, 3 }, { “subscribe_server_notifications”, 0 }, { “unlock”, 2 }, { “unmount”, 0 }, { “update”, 1 }, { “update_asset”, 2 }, { “update_asset_with_hash”, 2 }, { “update_object”, 2 } }’)
(‘Tick’, ‘provider_nucleus’, LogLevel.INFO, ‘Server omniverse://localhost supports atomic checkpoints’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘<< {“command”:“omni_objects2”,“id”:2}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘<< {“command”:“versioning”,“id”:3}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“OK”,“enabled”:true,“id”:3}’)
(‘Tick’, ‘provider_nucleus’, LogLevel.INFO, ‘Server omniverse://localhost supports checkpoints and it is enabled’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“OK”,“ext_value_min_size”:262144,“id”:2}’)
(‘Tick’, ‘provider_nucleus’, LogLevel.INFO, ‘Server omniverse://localhost supports omni-objects and it is enabled’)
(‘Tick’, ‘provider_nucleus’, LogLevel.INFO, ‘Connected to omniverse://localhost’)
(‘Tick’, ‘provider_nucleus’, LogLevel.DEBUG, ‘ListCache miss! omniverse://localhost/Users/cemck/iot-samples/’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘<< {“command”:“subscribe_list”,“id”:4,“path”:{“branch”:“”,“path”:“/Users/cemck/iot-samples/”}}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘<< {“command”:“list2”,“id”:5,“path”:“/Users/cemck/iot-samples/”}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“LATEST”,“id”:4}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“OK”,“ts”:{“omni_server_out_ts”:13347694223647151},“entries”:[{“path”:“/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/”,“branch”:“default”,“acl”:[“admin”,“write”,“read”],“created_timestamp”:1714669346,“modified_timestamp”:1714669346,“path_type”:“folder”,“empty”:false,“mounted”:false,“created_by”:“cemck”,“modified_by”:“cemck”}],“id”:5}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“DONE”,“ts”:{“omni_server_out_ts”:13347694223647167},“id”:5}’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 1: Stat(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01) returned Ok’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 1: copy(file:C:\Users\cemck\Documents\BA\Omniverse\iot-samples\content/ConveyorBelt_A08_PR_NVD_01 => omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01) returned Error: Already Exists’)
(‘Main’, ‘core’, LogLevel.VERBOSE, ‘Request 5: resolve(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/ConveyorBelt_A08_PR_NVD_01.usd)’)
(‘Tick’, ‘provider_nucleus’, LogLevel.DEBUG, ‘ListCache miss! omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘<< {“command”:“subscribe_list”,“id”:6,“path”:{“branch”:“”,“path”:“/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/”}}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘<< {“command”:“list2”,“id”:7,“path”:“/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/”}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“LATEST”,“id”:6}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“OK”,“ts”:{“omni_server_out_ts”:13347694223666584},“entries”:[{“path”:“/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/”,“branch”:“default”,“acl”:[“admin”,“write”,“read”],“created_timestamp”:1714669351,“modified_timestamp”:1714669351,“path_type”:“folder”,“empty”:false,“mounted”:false,“created_by”:“cemck”,“modified_by”:“cemck”},{“path”:“/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.thumbs/”,“branch”:“default”,“acl”:[“admin”,“write”,“read”],“created_timestamp”:1714669346,“modified_timestamp”:1714669346,“path_type”:“folder”,“empty”:false,“mounted”:false,“created_by”:“cemck”,“modified_by”:“cemck”},{“path”:“/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/ConveyorBelt_A08_PR_NVD_01.usd”,“branch”:“default”,“etag”:“3”,“acl”:[“admin”,“write”,“read”],“created_timestamp”:1714669346,“modified_timestamp”:1714669346,“path_type”:“asset”,“size”:27433930,“empty”:false,“mounted”:false,“created_by”:“cemck”,“modified_by”:“cemck”,“hash_type”:“sha-256-flat”,“hash_value”:“976c31c1c016d2bdfa4fac5eed8a4ccc72a5d1f1c367cbee3755f46ce14d50db”,“hash_bsize”:1048576,“checkpointed”:true,“transaction_id”:13,“checkpoint_count”:1},{“path”:“/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/Materials/”,“branch”:“default”,“acl”:[“admin”,“write”,“read”],“created_timestamp”:1714669346,“modified_timestamp”:1714669346,“path_type”:“folder”,“empty”:false,“mounted”:false,“created_by”:“cemck”,“modified_by”:“cemck”}],“id”:7}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“DONE”,“ts”:{“omni_server_out_ts”:13347694223666617},“id”:7}’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 5: resolve(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/ConveyorBelt_A08_PR_NVD_01.usd): Found omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/ConveyorBelt_A08_PR_NVD_01.usd’)
(‘Main’, ‘core’, LogLevel.VERBOSE, ‘Request 8: resolve(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/ConveyorBelt_A08_PR_NVD_01.usd)’)
(‘Tick’, ‘provider_nucleus’, LogLevel.DEBUG, ‘ListCache hit! omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 8: resolve(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/ConveyorBelt_A08_PR_NVD_01.usd): Found omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/ConveyorBelt_A08_PR_NVD_01.usd’)
(‘Main’, ‘core’, LogLevel.VERBOSE, ‘Request 10: getLocalFile(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/ConveyorBelt_A08_PR_NVD_01.usd)’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 10: getLocalFile: omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/ConveyorBelt_A08_PR_NVD_01.usd already exists as C:\Users\cemck\AppData\Local\ov\cache\client\omniverse\976c31c1c016d2bdfa4fac5eed8a4ccc72a5d1f1c367cbee3755f46ce14d50db.usd, not downloading’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 10: getLocalFile(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/ConveyorBelt_A08_PR_NVD_01.usd): Ok C:\Users\cemck\AppData\Local\ov\cache\client\omniverse\976c31c1c016d2bdfa4fac5eed8a4ccc72a5d1f1c367cbee3755f46ce14d50db.usd’)
(‘File IO’, ‘provider_file’, LogLevel.VERBOSE, ‘GetFileAttributesExW() returned “Das System kann den angegebenen Pfad nicht finden.”’)
(‘Main’, ‘core’, LogLevel.VERBOSE, ‘Request 14: resolve(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/ConveyorBelt_A08_PR_NVD_01.usd)’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 14: resolve(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/ConveyorBelt_A08_PR_NVD_01.usd): Found omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/ConveyorBelt_A08_PR_NVD_01.usd’)
(‘Main’, ‘core’, LogLevel.VERBOSE, ‘Request 16: resolve(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/Materials/conveyors.material.usda)’)
(‘Tick’, ‘provider_nucleus’, LogLevel.DEBUG, ‘ListCache miss! omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/Materials/’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘<< {“command”:“subscribe_list”,“id”:8,“path”:{“branch”:“”,“path”:“/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/Materials/”}}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘<< {“command”:“list2”,“id”:9,“path”:“/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/Materials/”}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“LATEST”,“id”:8}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“OK”,“ts”:{“omni_server_out_ts”:13347694223671873},“entries”:[{“path”:“/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/Materials/Base/”,“branch”:“default”,“acl”:[“admin”,“write”,“read”],“created_timestamp”:1714669346,“modified_timestamp”:1714669346,“path_type”:“folder”,“empty”:false,“mounted”:false,“created_by”:“cemck”,“modified_by”:“cemck”},{“path”:“/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/Materials/ConveyorBelt_A.mdl”,“branch”:“default”,“etag”:“1”,“acl”:[“admin”,“write”,“read”],“created_timestamp”:1714669346,“modified_timestamp”:1714669346,“path_type”:“asset”,“size”:1933,“empty”:false,“mounted”:false,“created_by”:“cemck”,“modified_by”:“cemck”,“hash_type”:“sha-256-flat”,“hash_value”:“f3055af5c7e918952c44fbb72727ecef7ddcd5bc4c4152b0ab8625edb88bdd76”,“hash_bsize”:1048576,“checkpointed”:true,“transaction_id”:11,“checkpoint_count”:1},{“path”:“/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/Materials/ConveyorDecal_A.mdl”,“branch”:“default”,“etag”:“2”,“acl”:[“admin”,“write”,“read”],“created_timestamp”:1714669346,“modified_timestamp”:1714669346,“path_type”:“asset”,“size”:1937,“empty”:false,“mounted”:false,“created_by”:“cemck”,“modified_by”:“cemck”,“hash_type”:“sha-256-flat”,“hash_value”:“85e117bb3d425f0baea0dcdb15cae7be7867f375c0cc7dae79824d88c8e992bf”,“hash_bsize”:1048576,“checkpointed”:true,“transaction_id”:12,“checkpoint_count”:1},{“path”:“/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/Materials/ConveyorTrim_A.mdl”,“branch”:“default”,“etag”:“11”,“acl”:[“admin”,“write”,“read”],“created_timestamp”:1714669346,“modified_timestamp”:1714669346,“path_type”:“asset”,“size”:1933,“empty”:false,“mounted”:false,“created_by”:“cemck”,“modified_by”:“cemck”,“hash_type”:“sha-256-flat”,“hash_value”:“69c831fbeca756ce64f074a7ed805fd73f03bc530aa8753f84e82305c8309c1d”,“hash_bsize”:1048576,“checkpointed”:true,“transaction_id”:15,“checkpoint_count”:1},{“path”:“/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/Materials/conveyors.material.usda”,“branch”:“default”,“etag”:“4”,“acl”:[“admin”,“write”,“read”],“created_timestamp”:1714669346,“modified_timestamp”:1714669346,“path_type”:“asset”,“size”:127453,“empty”:false,“mounted”:false,“created_by”:“cemck”,“modified_by”:“cemck”,“hash_type”:“sha-256-flat”,“hash_value”:“7775e17fa178d187c9d959ddd41d6a3f43de45d5912b3f3f761bf6a4bcfb51eb”,“hash_bsize”:1048576,“checkpointed”:true,“transaction_id”:14,“checkpoint_count”:1},{“path”:“/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/Materials/textures/”,“branch”:“default”,“acl”:[“admin”,“write”,“read”],“created_timestamp”:1714669346,“modified_timestamp”:1714669346,“path_type”:“folder”,“empty”:false,“mounted”:false,“created_by”:“cemck”,“modified_by”:“cemck”}],“id”:9}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“DONE”,“ts”:{“omni_server_out_ts”:13347694223671914},“id”:9}’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 16: resolve(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/Materials/conveyors.material.usda): Found omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/Materials/conveyors.material.usda’)
(‘Main’, ‘core’, LogLevel.VERBOSE, ‘Request 19: getLocalFile(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/Materials/conveyors.material.usda)’)
(‘Tick’, ‘provider_nucleus’, LogLevel.DEBUG, ‘ListCache hit! omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/Materials/’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 19: getLocalFile: omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/Materials/conveyors.material.usda already exists as C:\Users\cemck\AppData\Local\ov\cache\client\omniverse\7775e17fa178d187c9d959ddd41d6a3f43de45d5912b3f3f761bf6a4bcfb51eb.usda, not downloading’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 19: getLocalFile(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/Materials/conveyors.material.usda): Ok C:\Users\cemck\AppData\Local\ov\cache\client\omniverse\7775e17fa178d187c9d959ddd41d6a3f43de45d5912b3f3f761bf6a4bcfb51eb.usda’)
(‘Main’, ‘core’, LogLevel.VERBOSE, ‘Request 23: list(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live)’)
(‘Tick’, ‘provider_nucleus’, LogLevel.DEBUG, ‘ListCache miss! omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘<< {“command”:“subscribe_list”,“id”:10,“path”:{“branch”:“”,“path”:“/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/”}}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘<< {“command”:“list2”,“id”:11,“path”:“/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/”}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“LATEST”,“id”:10}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“OK”,“ts”:{“omni_server_out_ts”:13347694223680203},“entries”:[{“path”:“/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/Default.live/”,“branch”:“default”,“acl”:[“admin”,“write”,“read”],“created_timestamp”:1714863767,“modified_timestamp”:1714863767,“path_type”:“folder”,“empty”:false,“mounted”:false,“created_by”:“cemck”,“modified_by”:“cemck”},{“path”:“/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/”,“branch”:“default”,“acl”:[“admin”,“write”,“read”],“created_timestamp”:1714669351,“modified_timestamp”:1714669351,“path_type”:“folder”,“empty”:false,“mounted”:false,“created_by”:“cemck”,“modified_by”:“cemck”}],“id”:11}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“DONE”,“ts”:{“omni_server_out_ts”:13347694223680221},“id”:11}’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 23: list(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live) returned Ok with 2 entries’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 23: folder Default.live’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 23: folder iot_session.live’)
(‘Main’, ‘core’, LogLevel.VERBOSE, ‘Request 26: resolve(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/root.live)’)
(‘Tick’, ‘provider_nucleus’, LogLevel.DEBUG, ‘ListCache miss! omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘<< {“command”:“subscribe_list”,“id”:12,“path”:{“branch”:“”,“path”:“/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/”}}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘<< {“command”:“list2”,“id”:13,“path”:“/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/”}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“LATEST”,“id”:12}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“OK”,“ts”:{“omni_server_out_ts”:13347694223681432},“entries”:[{“path”:“/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/session.channel”,“branch”:“default”,“acl”:[“admin”,“write”,“read”],“created_timestamp”:1714673511,“modified_timestamp”:1714673511,“path_type”:“channel”,“empty”:true,“mounted”:false,“created_by”:“cemck”,“modified_by”:“cemck”},{“path”:“/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/session.toml”,“branch”:“default”,“etag”:“245”,“acl”:[“admin”,“write”,“read”],“created_timestamp”:1714669351,“modified_timestamp”:1714669351,“path_type”:“asset”,“size”:192,“empty”:false,“mounted”:false,“created_by”:“cemck”,“modified_by”:“cemck”,“hash_type”:“sha-256-flat”,“hash_value”:“40d44d55d07eaf90c666255e309890ce86112aff49f57f5af47aa381b45cc547”,“hash_bsize”:1048576,“checkpointed”:true,“transaction_id”:362,“locked_by”:“cemck”,“lock_time”:1714863818,“lock_owner”:“BQKZJY2BXDQQBYE1”,“lock_duration”:315360000.0,“lock_etag”:“245”,“checkpoint_count”:1},{“path”:“/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/root.live”,“branch”:“default”,“acl”:[“admin”,“write”,“read”],“created_timestamp”:1714669351,“modified_timestamp”:1714865090,“path_type”:“omniobject”,“mounted”:false,“created_by”:“cemck”,“modified_by”:“cemck”,“checkpointed”:false,“transaction_id”:902},{“path”:“/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/shared_data/”,“branch”:“default”,“acl”:[“admin”,“write”,“read”],“created_timestamp”:1714673515,“modified_timestamp”:1714673515,“path_type”:“folder”,“empty”:false,“mounted”:false,“created_by”:“cemck”,“modified_by”:“cemck”}],“id”:13}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“DONE”,“ts”:{“omni_server_out_ts”:13347694223681466},“id”:13}’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 26: resolve(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/root.live): Found omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/root.live’)
(‘Main’, ‘core’, LogLevel.VERBOSE, ‘Request 29: resolve(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/root.live)’)
(‘Tick’, ‘provider_nucleus’, LogLevel.DEBUG, ‘ListCache hit! omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 29: resolve(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/root.live): Found omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/root.live’)
(‘Main’, ‘core’, LogLevel.VERBOSE, ‘Request 31: liveReadObject(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/root.live, objectId=0, haveSequenceNum=0)’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘0000021DFB78B4E0 connecting to ws://127.0.0.1:3009’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘Created connection 0000021DFB788130’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘<< {“client_capabilities”:{“add_user_to_group”:0,“auth”:5,“authorize_token”:4,“change_acl”:0,“checkpoint_version”:2,“copy”:2,“copy2”:2,“create”:2,“create_asset”:2,“create_asset_with_hash”:2,“create_directory”:1,“create_group”:0,“create_object”:2,“deep_copy_object_struct”:0,“delete”:0,“delete2”:1,“get_acl”:0,“get_acl_resolved”:0,“get_acl_v2”:0,“get_branches”:1,“get_checkpoints”:1,“get_group_users”:0,“get_groups”:0,“get_mount_info”:0,“get_transaction_id”:0,“get_user_groups”:0,“get_users”:0,“list”:5,“list2”:5,“lock”:3,“mount”:0,“ping”:0,“read”:2,“read_asset_resolved”:0,“read_asset_version”:0,“read_object_resolved”:0,“read_object_version”:0,“remove_group”:0,“remove_user_from_group”:0,“rename”:2,“rename2”:1,“rename_group”:0,“replace_version”:1,“service_resolve_acl”:2,“service_subscribe_list”:1,“set_acl_v2”:0,“set_path_options”:1,“set_path_options2”:0,“set_user_agent”:0,“stat2”:2,“subscribe_list”:4,“subscribe_read_asset”:2,“subscribe_read_object”:3,“subscribe_server_notifications”:0,“unlock”:2,“unmount”:0,“update”:1,“update_asset”:2,“update_asset_with_hash”:2,“update_object”:2},“command”:“auth”,“id”:1,“token”:“EW5A2COG7VWAGBGZ”,“version”:“1.19”}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘<< {“command”:“subscribe_read_object”,“id”:14,“path”:{“branch”:“”,“path”:“/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/root.live”}}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘0000021DF99C9900 Upgraded to WebSocket’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“OK”,“server_capabilities”:{“add_user_to_group”:0,“auth”:5,“authorize_token”:4,“change_acl”:0,“checkpoint_version”:2,“copy”:2,“copy2”:2,“create”:2,“create_asset”:2,“create_asset_with_hash”:2,“create_directory”:1,“create_group”:0,“create_object”:2,“deep_copy_object_struct”:0,“delete”:0,“delete2”:1,“get_acl”:0,“get_acl_resolved”:0,“get_acl_v2”:0,“get_branches”:1,“get_checkpoints”:1,“get_group_users”:0,“get_groups”:0,“get_mount_info”:0,“get_transaction_id”:0,“get_user_groups”:0,“get_users”:0,“list”:5,“list2”:5,“lock”:3,“mount”:0,“ping”:0,“read”:2,“read_asset_resolved”:0,“read_asset_version”:0,“read_object_resolved”:0,“read_object_version”:0,“remove_group”:0,“remove_user_from_group”:0,“rename”:2,“rename2”:1,“rename_group”:0,“replace_version”:1,“service_resolve_acl”:2,“service_subscribe_list”:1,“set_acl_v2”:0,“set_path_options”:1,“set_path_options2”:0,“set_user_agent”:0,“stat2”:2,“subscribe_list”:4,“subscribe_read_asset”:2,“subscribe_read_object”:3,“subscribe_server_notifications”:0,“unlock”:2,“unmount”:0,“update”:1,“update_asset”:2,“update_asset_with_hash”:2,“update_object”:2},“ts”:{“omni_server_out_ts”:13347694223683831},“version”:""1.14.37-0959a9e9" ",“username”:“cemck”,“token”:“EW5A2COG7VWAGBGZ”,“connection_id”:“FMJBE9LKRFJ6ZNMT”,“connection_id_signature”:“2c3beda71d8f294e90304d3509017ca8e6bc134a4439817d72a0bd85748d5c37”,“max_chunk_size”:134217728,“lft_address”:"http://127.0.0.1:3030",“lft_threshold”:65536,“super_user”:true,“multipart_chunk_size”:5242880,“max_in_flight_requests”:0,“id”:1}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘<< {“command”:“ping”,“id”:2,“ts”:{“omni_client_out_ts”:13347694223684070}}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“OK”,“sequence”:14,“size”:6168,“object_id”:1,“id”:14}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> id=14 6168B#’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 31: liveReadObject(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/root.live, objectId=0, haveSequenceNum=0) returned Ok (objectId=1, sequenceNum=14, 6168 bytes)’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“LATEST”,“sequence”:0,“object_id”:1,“id”:14}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> id=14 0B#’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 31: liveReadObject(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/root.live, objectId=0, haveSequenceNum=0) returned Latest (objectId=1, sequenceNum=0, 0 bytes)’)
(‘Main’, ‘core’, LogLevel.VERBOSE, ‘Request 33: resolve(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/root.live)’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“OK”,“ts”:{“omni_client_out_ts”:13347694223684070,“omni_server_in_ts”:13347694223684221,“omni_c2s_lat”:151,“omni_server_out_ts”:13347694223684293},“username”:“cemck”,“token”:“EW5A2COG7VWAGBGZ”,“connection_id”:“FMJBE9LKRFJ6ZNMT”,“max_chunk_size”:134217728,“version”:""1.14.37-0959a9e9" ",“id”:2}’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 33: resolve(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/root.live): Found omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/root.live’)
(‘Main’, ‘core’, LogLevel.VERBOSE, ‘Request 35: resolve(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/root.live)’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 35: resolve(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/root.live): Found omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/root.live’)
(‘Main’, ‘core’, LogLevel.VERBOSE, ‘Request 37: resolve(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/root.live)’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 37: resolve(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/root.live): Found omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/root.live’)
(‘20540’, ‘core’, LogLevel.VERBOSE, ‘Request 39: resolve(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/Materials/conveyors.material.usda)’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 39: resolve(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/Materials/conveyors.material.usda): Found omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/Materials/conveyors.material.usda’)
(‘Main’, ‘core’, LogLevel.VERBOSE, ‘Request 41: resolve(C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdLux/resources/generatedSchema.usda)’)
(‘22596’, ‘core’, LogLevel.VERBOSE, ‘Request 43: resolve(C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdHydra/resources/generatedSchema.usda)’)
(‘22544’, ‘core’, LogLevel.VERBOSE, ‘Request 44: resolve(C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdRender/resources/generatedSchema.usda)’)
(‘23428’, ‘core’, LogLevel.VERBOSE, ‘Request 45: resolve(C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdMedia/resources/generatedSchema.usda)’)
(‘23276’, ‘core’, LogLevel.VERBOSE, ‘Request 48: resolve(C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdRi/resources/generatedSchema.usda)’)
(‘20540’, ‘core’, LogLevel.VERBOSE, ‘Request 52: resolve(C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usd/resources/generatedSchema.usda)’)
(‘25060’, ‘core’, LogLevel.VERBOSE, ‘Request 51: resolve(C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdShade/resources/generatedSchema.usda)’)
(‘9816’, ‘core’, LogLevel.VERBOSE, ‘Request 53: resolve(C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdVol/resources/generatedSchema.usda)’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 41: resolve(C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdLux/resources/generatedSchema.usda): Found C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdLux/resources/generatedSchema.usda’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 43: resolve(C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdHydra/resources/generatedSchema.usda): Found C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdHydra/resources/generatedSchema.usda’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 51: resolve(C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdShade/resources/generatedSchema.usda): Found C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdShade/resources/generatedSchema.usda’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 53: resolve(C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdVol/resources/generatedSchema.usda): Found C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdVol/resources/generatedSchema.usda’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 48: resolve(C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdRi/resources/generatedSchema.usda): Found C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdRi/resources/generatedSchema.usda’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 52: resolve(C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usd/resources/generatedSchema.usda): Found C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usd/resources/generatedSchema.usda’)
(‘22596’, ‘core’, LogLevel.VERBOSE, ‘Request 57: resolve(C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdGeom/resources/generatedSchema.usda)’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 44: resolve(C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdRender/resources/generatedSchema.usda): Found C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdRender/resources/generatedSchema.usda’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 45: resolve(C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdMedia/resources/generatedSchema.usda): Found C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdMedia/resources/generatedSchema.usda’)
(‘25060’, ‘core’, LogLevel.VERBOSE, ‘Request 59: resolve(C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdUI/resources/generatedSchema.usda)’)
(‘23276’, ‘core’, LogLevel.VERBOSE, ‘Request 61: resolve(C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdPhysics/resources/generatedSchema.usda)’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 57: resolve(C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdGeom/resources/generatedSchema.usda): Found C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdGeom/resources/generatedSchema.usda’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 59: resolve(C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdUI/resources/generatedSchema.usda): Found C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdUI/resources/generatedSchema.usda’)
(‘9816’, ‘core’, LogLevel.VERBOSE, ‘Request 63: resolve(C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdProc/resources/generatedSchema.usda)’)
(‘20540’, ‘core’, LogLevel.VERBOSE, ‘Request 65: resolve(C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdSkel/resources/generatedSchema.usda)’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 63: resolve(C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdProc/resources/generatedSchema.usda): Found C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdProc/resources/generatedSchema.usda’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 65: resolve(C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdSkel/resources/generatedSchema.usda): Found C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdSkel/resources/generatedSchema.usda’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 61: resolve(C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdPhysics/resources/generatedSchema.usda): Found C:/Users/cemck/Documents/BA/Omniverse/iot-samples/_build/target-deps/usd/release/lib/usd/usdPhysics/resources/generatedSchema.usda’)
(‘Main’, ‘core’, LogLevel.VERBOSE, ‘Request 67: liveUpdateObject(omniverse://localhost/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/root.live, 1240 bytes)’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘<< {“command”:“update_object”,“id”:15,“object_id”:1,“path”:{“branch”:“”,“path”:“/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/root.live”},“ts”:{“est”:13347694223699735}}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘<< id=15 1240B#’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“OK”,“ts”:{“omni_server_out_ts”:13347694223700366},“event”:“delta”,“entry”:{“path”:“/Users/cemck/iot-samples/ConveyorBelt_A08_PR_NVD_01/.live/ConveyorBelt_A08_PR_NVD_01.live/iot_session.live/root.live”,“branch”:“default”,“acl”:[“admin”,“write”,“read”],“created_timestamp”:1714669351,“modified_timestamp”:1714865097,“path_type”:“omniobject”,“mounted”:false,“created_by”:“cemck”,“modified_by”:“cemck”,“checkpointed”:false},“id”:12}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“OK”,“sequence”:15,“ts”:{“omni_server_out_ts”:13347694223700426},“transaction_id”:903,“id”:15}’)
usd composer shows this error every time i run the python script:
2024-05-07 14:01:11 [Warning] [omni.hydra] Mesh ‘/World/cube/mesh’ has corrupted data in primvar ‘st’: buffer size 4 doesn’t match expected size 8 in varying primvars
Ok well I am sorry if one our examples is having trouble. I will let the team know.
Issue fixed, check latest pull request on GitHub
