My Jetbot changed it’s IP address. How do I set ip back to original address and disable hdmi? This is a Nano 2gb.
JupyterLab cannot access it. Reply is “refused to connect”. I suspect it changed to an address already in use by another device on my network.
Moving this topic to the Jetson Nano forum from Other Tools.
Connect a monitor to it and manually set the IP by mouse and keyboard.
I guess I should have mentioned that I had a monitor, keyboard, and mouse connected, and that I was trying to find out where to find the IP address to change it and where to turn off dhcp.
This is a ubuntu system. If you want to know how to change IP, you can also use google search to find out the answer.
Thank you. I am getting back into this after decades away from older cli Unix and variants. It’s a different world nowadays.
