IP Camera compatibility with Xavier
I need to use the following IP camera, with the following specification:
I see no specific reason for incompatibility. But wanted to know what others think, so that I can rely on it.
The camera sensor seems to be Progressive scan CMOS; I have no idea if its supported by Xavier, also, there is no mention of support for Linux, so is this something to worry about? Can I be sure about it ?
hello pradan,
you should not worried about the scan types of IP camera, since it’ll handle signaling by itself and sending compress data through ethernet for usage.
it’s usually using RTSP protocol to communicate with IP camera, there’s discussion thread, you may refer to Topic 78790 for enabling deepstream-app with RTSP source.
you may also contact with Jetson Preferred Partners for supported sensor modules of your camera solutions.
thanks
