Ip camera + static ip = problem, need help
And you can modify the address to other kind so that it may prevent conflict. For example, set IP cam related IP to 10.0.0.1
Thanks, what i did in the end is restarted camera, made sure that dhcp server works correctly and suet subdomain 10.10.10.1. all works, thanks
This issue sounds like IP conflict because you set 192.168.1.x with netmask 255.255.255.0. Thus, changing the IP would work.
Exactly what was going on. Like I said, Iā€™m no expert, just a regular guy playing with new toy :) so lots of unknowns
