I’m trying to link a C program against some C and fortran libraries and am runnning into this problem:
IPA fatal error: function ‘_free’ multiply defined in: …/src/pgf90rtl.c
IPA fatal error: function ‘_free’ multiply defined in: …/src/libc.c
IPA fatal error: function ‘_malloc’ multiply defined in: …/src/pgf90rtl.c
IPA fatal error: function ‘_malloc’ multiply defined in: …/src/libc.c
IPA inhibited: multiply defined routines
I can’t seem to reproduce it in a minimal way, so here is my link statement.
pgcc -IZ:/ISLtools_v1.2/i686-pc-winnt-gnu/include -I…/…/…/src/scats -I…/…/…/src/scats/libscatsio -I…/…/…/src/scats/libscats -Ic:/cygwin/usr/local/include -Ic:/cygwin/usr/local/include -fastsse -O3 -Mipa=fast -Mvect=sse -s -m32 -DZ_PREFIX -o CellScatter.exe CellScatter.o -Lc:/PROGRA~1/PGI/nt86/6.0/mingw/lib -Lc:/PROGRA~1/PGI/nt86/6.0/mingw/mingw32/lib -Lc:/PROGRA~1/PGI/nt86/6.0/mingw/lib/gcc-lib/mingw32/2.95.3-5 -Lc:/PROGRA~1/PGI/nt86/6.0/lib -lpgmm1 -lpgmm2 -lpgf90 -lpgf90_rpm1 -lpgf902 -lpgf90rtl -lpgftnrtl -lpgsse1 -lpgsse2 -lpgc -lmingw32 -lmoldname -lmsvcrt -luser32 -ladvapi32 -lshell32 -lkernel32 …/libscats/.libs/libscats.lib …/libseke/.libs/libseke.lib …/libscatsio/.libs/libscatsio.lib -LZ:/ISLtools_v1.2/i686-pc-winnt-gnu/lib Z:/ISLtools_v1.2/i686-pc-winnt-gnu/lib/libisl.lib -Lc:/cygwin/usr/local/lib -lvsip -lmatio -lz -lmingwex
I get the same error if i remove the explicit linking against the fortran libraries and replace it with -pgf90libs and I get fortran undefined symbols obviously if I don’t use either method.
Stumped,
Chris
Hi Chris,
I’ll need to do a bit of investigation since off hand I don’t know why this would occur. Let’s try some things to at least get your program to link.
Try linking with “pgf90 -Mnomain” instead of “pgcc”. Also remove all the “-lpg*” libraries.
Since the errors are from pgipa, remove “-Mipa=fast” and re-link.
Part 2 works fine. Then again I think it just skips IPA and continues linking anyways.
pgf90 with -Mnomain gives the same error
pgf90 -Mnomain -IZ:/ISLtools_v1.2/i686-pc-winnt-gnu/include -I…/…/…/src/scats -I…/…/…/src/scats/libscatsio -I…/…/…/src/scats/libscats -Ic:/cygwin/usr/local/include -Ic:/cygwin/usr/local/include -fastsse -O3 -Mipa=fast -Mvect=sse -s -m32 -DZ_PREFIX -o CellScatter.exe CellScatter.o -lmoldname …/libscats/.libs/libscats.lib …/libseke/.libs/libseke.lib …/libscatsio/.libs/libscatsio.lib -LZ:/ISLtools_v1.2/i686-pc-winnt-gnu/lib Z:/ISLtools_v1.2/i686-pc-winnt-gnu/lib/libisl.lib -Lc:/cygwin/usr/local/lib -lvsip -lmatio -lz -lmingwex
c:\PROGRA~1\PGI/nt86/6.0/bin/ld.exe c:\PROGRA~1\PGI/nt86/6.0/mingw/lib/crt2.o c:\PROGRA~1\PGI/nt86/6.0/lib/pgstdinit-msv.o c:\PROGRA~1\PGI/nt86/6.0/lib/pgimainxx.o CellScatter.o …/libscats/.libs/libscats.lib …/libseke/.libs/libseke.lib …/libscatsio/.libs/libscatsio.lib Z:/ISLtools_v1.2/i686-pc-winnt-gnu/lib/libisl.lib -s -o CellScatter.exe -LZ:/ISLtools_v1.2/i686-pc-winnt-gnu/lib -Lc:/cygwin/usr/local/lib -Lc:\PROGRA~1\PGI/nt86/6.0/mingw/lib -Lc:\PROGRA~1\PGI/nt86/6.0/mingw/mingw32/lib -Lc:\PROGRA~1\PGI/nt86/6.0/mingw/lib/gcc-lib/mingw32/2.95.3-5 -Lc:\PROGRA~1\PGI/nt86/6.0/lib -lvsip -lmatio -lz -lmingwex -lpgmm1 -lpgmm2 -lpgf90 -lpgf90_rpm1 -lpgf902 -lpgf90rtl -lpgftnrtl -lpgsse1 -lpgsse2 -lpgc -lmingw32 -lgcc -lmoldname -lmsvcrt -luser32 -lkernel32 -ladvapi32 -lshell32
pgf90-Warning-Unknown switch: -m32
c:\PROGRA~1\PGI/nt86/6.0/bin/pgipa.EXE -v -finalo CellScatter.exe -ignore ‘-Mextract -L -I -Mkeepasm -Mpreprocess -l -Minline’ -nop -cp -const -align -const -range -globals -div -trans -arg -arglocal -ptr -f90ptr -shape -lm -lc c:\PROGRA~1\PGI/nt86/6.0/bin/ld.exe c:\PROGRA~1\PGI/nt86/6.0/mingw/lib/crt2.o c:\PROGRA~1\PGI/nt86/6.0/lib/pgstdinit-msv.o c:\PROGRA~1\PGI/nt86/6.0/lib/pgimainxx.o CellScatter.o …/libscats/.libs/libscats.lib …/libseke/.libs/libseke.lib …/libscatsio/.libs/libscatsio.lib Z:/ISLtools_v1.2/i686-pc-winnt-gnu/lib/libisl.lib -s -o CellScatter.exe -LZ:/ISLtools_v1.2/i686-pc-winnt-gnu/lib -Lc:/cygwin/usr/local/lib -Lc:\PROGRA~1\PGI/nt86/6.0/mingw/lib -Lc:\PROGRA~1\PGI/nt86/6.0/mingw/mingw32/lib -Lc:\PROGRA~1\PGI/nt86/6.0/mingw/lib/gcc-lib/mingw32/2.95.3-5 -Lc:\PROGRA~1\PGI/nt86/6.0/lib -lvsip -lmatio -lz -lmingwex -lpgmm1 -lpgmm2 -lpgf90 -lpgf90_rpm1 -lpgf902 -lpgf90rtl -lpgftnrtl -lpgsse1 -lpgsse2 -lpgc -lmingw32 -lgcc -lmoldname -lmsvcrt -luser32 -lkernel32 -ladvapi32 -lshell32
