IPluginV2 called during build phase and building failed
I rewrote my old plugins from IPlugin class to IPluginV2 class so I can upgrade my tensorRT7 to tensorRT8.
When I was running the usual pipeline (file parsing → engine building → inference), the process ended during building.
After a bit more investigation, I found that some custom plugins were called during building which did not happen in tensorRT7.
Can this be the reason why building failed? Is this normal for IPluginV2? Where do I start to debug?
mainboard.log.INFO.20221017-160406.3087681 (1.9 MB)
Jetpack 5.0
TRT: 8.4.0.9
GPU: Orin
CUDA: 11.4.166
Looks like this post is a duplicate of [pluginV2Runner.cpp::execute::265] Error Code 2: Internal Error (Assertion status == kSTATUS_SCUESS failed. ).
Thank you.
