IPluginV2Ext and TensorRT 5.1.5.0
class CastFloat2HalfLayer : public IPluginV2Ext
public:
    CastFloat2HalfLayer(const int num_elements)
        numElements = num_elements;
    CastFloat2HalfLayer(const void* data, size_t length)
        const char* d = static_cast<const char*>(data);
        numElements = read<int>(d);
    // It makes no sense to construct UffPoolPluginV2 without arguments.
    CastFloat2HalfLayer() = delete;
    virtual ~CastFloat2HalfLayer() {}
    int getNbOutputs() const override
        return 1;
    Dims getOutputDimensions(int index, const Dims* inputs, int nbInputDims) override
        assert(nbInputDims == 1);
        assert(inputs[0].nbDims == 3);
        assert(index == 0);
        int out_c = inputs[0].d[0];
        int out_h = inputs[0].d[1];
        int out_w = inputs[0].d[2];
        return DimsCHW(out_c, out_h, out_w);
    void attachToContext(cudnnContext *, cublasContext * , IGpuAllocator *) override { ; }
    bool canBroadcastInputAcrossBatch(int inputIndex) const override { return 0; }
    void configurePlugin(const Dims *  inputDims,
                          int   nbInputs,
                          const Dims *   outputDims,
                          int   nbOutputs,
                          const DataType *   inputTypes,
                          const DataType *   outputTypes,
                          const bool *   inputIsBroadcast,
                          const bool *   outputIsBroadcast,
                          PluginFormat   floatFormat,
                          int   maxBatchSize
                          )  override { numElements = inputDims[0].d[0] * inputDims[0].d[1] * inputDims[0].d[2]; }
    void detachFromContext() override { ; }
    DataType getOutputDataType(int index, const DataType* inputTypes, int nbInputs) const override { return DataType::kHALF; }
    int getTensorRTVersion() const override { return 5; }
    bool isOutputBroadcastAcrossBatch(int outputIndex, const bool * inputIsBroadcasted, int nbInputs ) const override { return 0; }
    int initialize() override { return 0; }
    void terminate() override { ; }
    size_t getWorkspaceSize(int maxBatchSize) const override { return 0; }
    int enqueue(int batch_size, const void*const *inputs, void** outputs, void*, cudaStream_t stream) override
        int num_elements = numElements;
        float *data_in = (float*)inputs[0];
        __half *data_out = (__half*)outputs[0];
        cudaCastFloatToHalf_device(data_in, data_out, num_elements, stream);
        return 0;
    size_t getSerializationSize() const { return sizeof(int); }
    void serialize(void* buffer) const
        char *d = reinterpret_cast<char*>(buffer);
        write(d, numElements);
    void configureWithFormat(const Dims* inputs, int nbInputs, const Dims* outputDims, int nbOutputs, nvinfer1::DataType type, nvinfer1::PluginFormat format, int maxBatchSize) override
        assert(nbOutputs == 1);
        assert(nbInputs == 1);
    bool supportsFormat(DataType type, PluginFormat format) const override { return (type == DataType::kFLOAT && format == PluginFormat::kNCHW); }
    const char* getPluginType() const override { return "CastFloat2Half_TRT"; }
    const char* getPluginVersion() const override { return "1"; }
    void destroy() override { delete this; }
    IPluginV2Ext* clone() const override { return new CastFloat2HalfLayer(numElements); }
    void setPluginNamespace(const char* libNamespace) override { mNamespace = libNamespace; }
    const char* getPluginNamespace() const override { return mNamespace.c_str(); }
private:
    template <typename T>
    void write(char*& buffer, const T& val) const
        *reinterpret_cast<T*>(buffer) = val;
        buffer += sizeof(T);
    T read(const char*& buffer)
        T val = *reinterpret_cast<const T*>(buffer);
        return val;
    int numElements;
    std::string mNamespace;
namespace
const char* CASTFLOAT2HALFLAYER_PLUGIN_VERSION{"1"};
const char* CASTFLOAT2HALFLAYER_PLUGIN_NAME{"CastFloat2Half_TRT"};
} // namespace
Hi fbrughi,
The error “invalid new-expression of abstract class type” means you’re attemping to instantiate an abstract class, ie a class with pure virtual functions on it. If you read further into your error message, it may even tell specifically which virtuals are still pure.
Take a look at the declaration of IPluginV2Ext: https://github.com/NVIDIA/TensorRT/blob/07ed9b57b1ff7c24664388e5564b17f7ce2873e5/include/NvInferRuntimeCommon.h#L480
You should see several pure virtuals which your plugin has left pure virtual (for example, isOutputBroadcastAcrossBatch).
Cheers,
Tom
