Hello Shane,
We have modified the IRS1125 driver and created separate “dtsi” files for the IRS1125 device ( Included in tegra210-porg-p3448-common.dtsi file ) to support with the Jetson Nano platform.
Attached the IRS1125 and common dtsi zip files for reference.
jetson-irs1125-dtsi.zip (16.7 KB)
With the above changes, the platform is capable to call the probe function of the IRS1125 driver.
The “driver insmod” process throws a segmentation fault. ( Logs are captured in the text file Jetson-IRS1125-logs.txt )
Jetson-IRS1125-logs.txt (11.2 KB)
[ 4.010531] Internal error: Accessing user space memory outside uaccess.h routines: 96000005 [#1] PREEMPT SMP
[ 4.020440] Modules linked in: overlay irs1125(+) nvgpu bluedroid_pm ip_tables x_tables
[ 4.028494] CPU: 0 PID: 2965 Comm: systemd-udevd Not tainted 4.9.140-tegra #33
[ 4.035705] Hardware name: MISTRAL Neuron Base Board (DT)
[ 4.041095] task: ffffffc0efec9c00 task.stack: ffffffc0efdc8000
[ 4.047010] PC is at tegra_channel_fmts_bitmap_init+0x21c/0x268
[ 4.052921] LR is at tegra_channel_fmts_bitmap_init+0x1e0/0x268
[ 4.058828] pc : [] lr : [] pstate: 60400045
[ 4.066210] sp : ffffffc0efdcb780
**[ 4.069516] x29: ffffffc0efdcb780 x28: 0000000000000018 **
**[ 4.074834] x27: 00000000000000cb x26: 0000000000000002 **
**[ 4.080151] x25: 0000000000000038 x24: 0000000000000001 **
**[ 4.085468] x23: ffffffc0f39e7418 x22: ffffffc0f75741e8 **
**[ 4.090783] x21: ffffffc0f7574018 x20: ffffffc0f39e7418 **
**[ 4.096097] x19: 00000000ffffffff x18: 0000000000000000 **
**[ 4.101414] x17: 0000000000000001 x16: 0000000000000007 **
**[ 4.106730] x15: 0000000000000000 x14: 0000000000000000 **
**[ 4.112043] x13: 0000000000000000 x12: 0000000000000006 **
**[ 4.117358] x11: 0000000000000002 x10: 00000000000002ec **
**[ 4.122674] x9 : 0000000000000001 x8 : 0000000000000001 **
**[ 4.127988] x7 : 000000000000000b x6 : 0000000000000000 **
**[ 4.133303] x5 : 0000000000000000 x4 : 000000000000000c **
**[ 4.138616] x3 : ffffffc0f7574360 x2 : 00000000000005a0 **
**[ 4.143929] x1 : 0000000000000160 x0 : 0000000000000000 **
[ 4.150729] Process systemd-udevd (pid: 2965, stack limit = 0xffffffc0efdc8000)
[ 4.158024] Call trace:
[ 4.160467] [] tegra_channel_fmts_bitmap_init+0x21c/0x268
[ 4.167418] [] tegra_channel_init_subdevices+0x17c/0x790
[ 4.174281] [] tegra_vi_graph_notify_complete+0x2e8/0x6e0
[ 4.181231] [] v4l2_async_test_notify+0x104/0x120
[ 4.187487] [] v4l2_async_register_subdev+0x88/0x100
[ 4.194010] [] irs1125_probe+0x344/0x438 [irs1125]
[ 4.200354] [] i2c_device_probe+0x144/0x258
[ 4.206091] [] driver_probe_device+0xd8/0x408
[ 4.211999] [] __driver_attach+0xdc/0x128
[ 4.217561] [] bus_for_each_dev+0x5c/0xa8
[ 4.223121] [] driver_attach+0x30/0x40
[ 4.228422] [] bus_add_driver+0x20c/0x2a8
[ 4.233984] [] driver_register+0x6c/0x110
[ 4.239546] [] i2c_register_driver+0x4c/0xb0
[ 4.245373] [] irs1125_driver_init+0x18/0x30 [irs1125]
[ 4.252064] [] do_one_initcall+0x44/0x130
[ 4.257626] [] do_init_module+0x64/0x1a8
[ 4.263103] [] load_module+0x10a4/0x12d8
[ 4.268577] [] SyS_finit_module+0xd8/0xf0
[ 4.274137] [] __sys_trace_return+0x0/0x4
[ 4.279699] —[ end trace 7fbccff4c3e391e6 ]—
Our plan is to use the IRS1125 device under the standard V4L2 driver.
Could you please help us to understand and fix this issue?
Thanks and Regards,
Ravikiran J J
