Is 15 Ohms between GND and VDD_IN of Jetson Nano module ok? Or it is shorted?
I have the Jetson Nano board with module not working. It seems that 241-250 GND pins and 251-260 VDD_IN pins of 260-pin connector are shorted. But module itself is showing 15 Ohms between GND and VDD_IN.
My question is - should I purchase and try with another carrier board, or Jetson Nano module is dead as well?
Is 15 Ohms between GND and VDD_IN is normal reading?
No, it is abnormal. You can probe the VDD_IN and GND of module without carrier board to make sure if module pins are shorted too.
Hi. Thank you for the reply!
Just to clarify - I have 15 Ohms between VDD_IN and GND of the module itself without carrier board.
The carrier board is totally shorted at VDD_IN and GND.
Could you please provide if possible the normal resistance readings between VDD_IN and GND of the module without carrier board?
