Is a third DGX Spark worth it? Looking for TP=3 vs TP=2 experiences
I have a Gigabyte AI TOP ATOM, which I use mostly for Qwen 3.8 27B and Qwen 3.8 Flash Next, and a second Spark (NVIDIA Founders Edition) has just arrived. Before prices rise further, I am considering a third. Four is out of the question for now.
Which models does a third Spark let you run that two cannot, or at a noticeably better quantization? For example, DeepSeek V4.1 Flash at native precision, or GLM 5.3 Flash with more concurrent 1M context requests. What single stream speeds do you get, and at what context length?
Are there any limitations with TP=3 (vLLM / SGLang vs TensorFold) that affect tools such as DSpark or DFlash 2? Have you had any problems with the switchless 3 node ring, or with mixing units from different vendors?
Or is it better to run the third Spark as a separate machine, e.g. a different model running alongside a 2-node cluster? I was considering running Qwen 3.8 Flash Next and GLM 5.3 Flash, for example.
TP only works on power of 2, so 3 is only pipeline parallelism, which most models does not support.
For 2 nodes glm-5.3 flash, and ds v4 (not v4.1) are solid, on 3rd you can run qwen3 or other <100B MoE models, but considering prices not sure you would gain anything, that tp=2 wont be able to give.
TP=4 diffrent story, yet even it barely runs pro level of models (glm-5.2, DS v4 pro, etc).
Not correct, that was the case 6+ months ago.
TP=3 is available a bunch of nice and fast recipes.
you can run ds41f at native weights if you have tp=3.
64 is not divisible on 3. yes, you can pad it to 96, and it will work, but that does not make it TP=3.
Sorry to disagree with you, but it can and does.
It certainly doesn’t make it PP=3.
On top of that you have a few models that natively will run TP=3 such as MiniMax M3.
minimax m3 query heads 64 and kv heads 4 config.json · MiniMaxAI/MiniMax-M3 at main
Don’t get me wrong, I agree you can pad it to closest dividable on 3 and you can set TP=3 to engine and it will discard calculated/transferred pads.
Thanks for your comments! @christopher_owen, could you share some numbers for native V4.1 Flash on TP=3? What is the largest context you managed to run (not just configured)? Also what tok/s did you get? How many concurrent requests managed to fit?
One user on reddit said it leaves very little KV cache at native precision, while another said they run 1M with 4 streams, after tuning.
@mashie which TP=3 recipes would you recommend? For which models?
I run TP=4 myself using a derived version of the MiaAI recipe linked above for DSv41F. It is an awesome daily driver and in my case twice as fast as DSv4F.
First and foremost, if your primary consideration is cost ($$$), it’s hard to beat commercial cloud-based frontier SOTA models, especially when you factor in performance, reliability, and service levels.
However, if your priorities are data privacy, local control, and reducing dependency on commercial frontier models, then running your own hardware becomes much easier to justify.
On a single DGX Spark, main use-case ComfyUI for video generation and Qwen Ultra Fast for local AI workloads. It’s a fairly practical setup for everyday experimentation without the additional complexity of multi-node configurations.
I recently embarked on a dual DGX Spark setup to experiment with larger models such as GLM 5.3, Qwen 3.8 Flash, and DeepSeek 4.
Don’t expect twice the throughput just because you have two Sparks. In fact, you may spend more time waiting for model shards to load, dealing with RoCE networking, and managing the additional complexity.
Is all that trouble worth it? For me, yes. It’s an interesting learning experience, and more importantly, it serves as a useful fallback when I run out of Codex tokens.
Would I recommend dual Sparks purely for cost savings or productivity? Probably not. But for experimentation, privacy, and the freedom (circumvent the guardrails) to run larger and “higher quality” models locally, there’s definitely value in it.
I’ll probably stop at two Sparks rather than invest in a third. At this point, I simply don’t see a compelling need for more than 256 GB of combined memory. Beyond that, the additional cost and complexity become increasingly difficult to justify, especially when commercial frontier models are just a subscription away.
I am curious about this too. anybody with the akward 3 spark infrastructure saw a net improvement from 2 to 3? I will have a 3rd one soon, but can’t afford 4.
yes, with 3 it’s possible to run ds41f native (without quantization).
This is pretty cool.
Thanks! do you have the github recipe for a 3xspark with ds41f native?
It’s the one I posted earlier.
@marcdein I was in the same spot, the best results I found in terms of quality vs. speed has been with @christopher_owen’s 3 spark DSF4.1 recipe. I will not go back to a 2 spark setup, the quality/speed is not there from the other Flash models for my work.
One thing I noticed @christopher_owen I am running the 512K context in a recipe you had from a few weeks ago and it feels slower for me. Should I go back to 256K context? … also I was away from the forum a bit and I think you have released an update in the last week?
At long context lengths, a cold cache will be noticeably slower, because the entire context has to be recomputed (prefilled) from scratch rather than reused from the prefix cache.
Have you changed anything in how you’re sending requests recently? For example, edits to the system prompt, reordered messages, or dynamic content such as timestamps near the start of the prompt can all invalidate the prompt cache and cause a full recompute on every request.
