Is an RTX 3060 enough to run Isaac Sim?
I have read in the docs, that a 2070 is minimum spec to run isaac sim. Will a rtx 3060 also suffice?
Thank you very much in advance.
I use an RTX 3070. I have nothing to compare with, it seems a little slow to load, but works fine after that.
Yes, the RTX 3060 is fine. Isaac Sim requires an RTX GPU with at least 8GB VRAM.
Okay thank you for your answer Peter
Thats very good news. Thank you for your answer Sheikh
