Is binary/raw tensor output supported in Triton Inference Server
Hi, I need to do some postprocessing on the output tensor to get final prediction results. I could either implement it in Triton (not sure how) or have Triton return raw sensor to me.
I’ve found the following doc which describes that it’s possible:
When I configure my model output like so:
output: [
        data_type: TYPE_FP32
        dims: [
                3,
                256,
                512
        label_filename: ""
        parameters: {
            binary_data: true
I get this error:
[libprotobuf ERROR /tmp/tritonbuild/tritonserver/build/_deps/repo-third-party-build/grpc-repo/src/grpc/third_party/protobuf/src/google/protobuf/text_format.cc:317] Error parsing text-format inference.ModelConfig: 36:11: Message type "inference.ModelOutput" has no field named "parameters".
It seems that parameters can’t be specified for input or output. I also don’t find parameters in protobuf file:
However, I see binary_tensor_data server extension enabled in the log below:
| Option                           | Value        |
| server_id                        | triton        |
| server_version                   | 2.21.0        |
| server_extensions                | classification sequence model_repository model_repository(unload_dependents) schedule_policy model_configuration system_shared_memory cuda_shared_memory binary_tensor_data statistics trace |
| model_repository_path[0]         | /models
I’m running the latest docker image: nvcr.io/nvidia/tritonserver:22.04-py3 and also tried nvcr.io/nvidia/tritonserver:21.07-py3 with the same result.
Do I need to build a custom image, enable extensions or is it simply not supported? A bit confused by the docs and availability of the extension.
If this feature is not supported, is there a way to provide custom postprocessing function to be run on the triton server?
Thank you,
Alex
