Is CUDA - OpenGL possible with a shared OpenGL context?
In our application, we are successfully using CUDA OpenGL interop. Our application uses some GLSL shaders to write into a texture (via a frame buffer) and subsequently reads the data from the texture in a CUDA kernel.
For performance reasons, we are moving to an asynchronous architecture. In this architecture, thread A writes the texture in OpenGL context A. Subsequently, we pass on the texture to thread B using OpenGL context B, which is shared with OpenGL context A.
This is what we do in pseudo-code:
void ApixaThread::run()
    if (!m_context->makeCurrent(m_surface.get()))
        Log::error("Failed to make the shared OpenGL context current to the Apixa thread.");
        return;
    if (!InitCuda())
        Log::error("Failed to initialize CUDA for the Apixa thread.");
        return;
    while (!isInterruptionRequested())
        Input input = GetNextFromQueue();
        GLuint tex_name = input.tpeIn->GetTextureID();
        glBindTexture(GL_TEXTURE_2D, tex_name);
        if (!OpenGLUtil::IsOpenGLSucces())
            Log::info("Failed to bind texture");
            continue;
        if (!MapOpenGlTextureInCuda(input.tpeIn))
            Log::error("Failed to map and OpenGL texture in CUDA: id={} is-texture={}", textureName, glIsTexture(tex_name));
            continue;
bool InitCuda(int deviceIndex = 0)
    CUresult cudaResult;
    CUdevice cuDevice {};
    cudaResult = cuDeviceGet(&cuDevice, deviceIndex);
    if (cudaResult != CUDA_SUCCESS)
        Log::error("Failed query the CUDA device with index {}: {}", deviceIndex, FmtCudaError(cudaResult));
        return false;
    char deviceNameBuffer[128] { 0 };
    cudaResult = cuDeviceGetName(deviceNameBuffer, 128, cuDevice);
        Log::error("Failed to query the device name: {}", FmtCudaError(cudaResult));
        return false;
    CUcontext cudaContext {};
    cudaResult = cuCtxCreate(&cudaContext, 0, cuDevice);
        Log::error("Failed to create a new CUDA context: {}", FmtCudaError(cudaResult));
        return false;
    cudaResult = cuCtxSetCurrent(cudaContext);
        Log::error("Failed to make the CUDA context current: {}", FmtCudaError(cudaResult));
        return false;
    Log::info("Successfully initialized CUDA device '{}', index {}", deviceNameBuffer, deviceIndex);
    return true;
bool MapOpenGlTextureInCuda(const PooledTextureRef& tpe)
    CUresult error;
    CUgraphicsResource m_pcudaResource;
    error = cuGraphicsGLRegisterImage(&m_pcudaResource, tpe->GetTextureID(), GL_TEXTURE_2D, CU_GRAPHICS_REGISTER_FLAGS_READ_ONLY);
    if (error != CUDA_SUCCESS)
        Log::error("Failed to register texture to CUDA: {}", FmtCudaError(error));
        return false;
    return true;
It would be great if someone could tell me if CUDA—OpenGL interop is possible with a shared texture or if this is already a losing strategy. I couldn’t find anything in the documentation that says this would not be possible.
Thanks,
Thomas
