Is cudaMemsetAsync available?
Can I use cudaMemsetAsync? If yes, what is the right way to use it?
When I have this:
istat=cudaMemsetAsync(fxpep_d,0.0d0,natom,stream4)
I get a compilation error:
PGF90-S-0038-Symbol, cudamemsetasync, has not been explicitly declared (test.f90)
Thanks,
Lam
Hi Lam,
Yes, but it’s not one we added to the CUDA Fortran interface module. Instead, you need to add your own explicit interface:
interface
   function cudaMemsetAsync(arr, value, bytes, stream) bind(c,name='cudaMemsetAsync')
     use iso_c_binding
     use cudafor
     integer(c_int),    value :: value, stream, cudaMemsetAsync
     integer(c_size_t), value :: bytes
     type(C_devptr), value :: arr
   end function cudaMemsetAsync
 end interface
Since cudaMemset only allowed for 32-bit values, we decided to write our own version which also allowed for 64-bit values. However, we did not create an async version as well.
  • Mat
Thanks Mat,
But how do I add this code of interface to my program? I’ve never used interface.
Lam
Hi Lam,
You’d just cut and paste this code into the definition section of the subroutine that’s calling cudaMemsetAsync or put it a module.
For details, I’d suggest getting a book on Fortran programing, in particular one that covers F90 and F2003.
  • Mat
Hi Mat,
Thanks for the tip.
Because the arrays I want to set values are of type double precision, I modify your code as following:
interface
  function cudaMemsetAsync(arr, val, bytes, stream) bind(c,name='cudaMemsetAsync')
    use iso_c_binding
    use cudafor
    integer(c_int),value :: stream, cudaMemsetAsync
    real(c_double),value::val
    type(c_devptr), value :: arr
end interface
And here is how I try to set the values of the arrays:
Now I got compiling errors with argument 1, 3 and 4 but not 2:
PGF90-S-0446-Argument number 1 to cudamemsetasync: rank mismatch (test.f90: 261)
PGF90-S-0450-Argument number 3 to cudamemsetasync: kind mismatch (test.f90: 261)
PGF90-S-0450-Argument number 4 to cudamemsetasync: kind mismatch (test.f90: 261)
I wonder if this is because I have the variables declared differently in the fortran code compared to that in C? Here is how I declare the related variables:
   integer(kind=cuda_stream_kind)::stream4
   double precision,allocatable,device::fxpep_d(:)
   integer natom
What did I do wrong here?
Thanks,
Lam
Hi Lam,
As I mentioned before, the reason why we wrote our own cudaMemSet, is because the CUDA C version only supports 32-bit data types. Hence, you can’t use a double here.
Memset isn’t an expensive operation. Do you really need it to be async?
Though to answer the specific compiling errors. For argument #1, you need to be passing in the pointer to the device array (via the “c_devloc(fxpep_d)” intrinsic). For “natom”, have it declared as an “integer(c_int)”. Finally, I’d update the interface so that “stream” is declared as “integer(kind=cuda_stream_kind)”. I should have caught that the interface is wrong.
  • Mat
Thanks Mat,
Lam
