hi
when i use GDS,cufio-fs may match super block magic num,if mismatch,it will fail lilke this:
cufio:1082 cuFileHandleRegister error: GPUDirect Storage not supported on current file
Related topics
Topic | Replies | Views | Activity | |
cuFileHandleRegister error: GPUDirect Storage not supported on current file | 0 | 837 | August 27, 2022 | |
GPUDirect Storage ERROR | 1 | 808 | June 29, 2021 | |
GDSIO run RAID0 have the error "file register error: GPUDirect Storage not supported on current file filename :/test/gdsio.0" | 0 | 759 | April 26, 2023 | |
Dose not T1000 GPU support GPU Direct Storage? | 0 | 39 | August 13, 2024 | |
GDS cufile-fs: cannot verify RAID members, RAID group size empty | 4 | 560 | February 8, 2024 | |
GPUDirect Storage issue on NVIDIA DGX A100 System | 10 | 1612 | January 16, 2024 | |
GPUDirect Storage - Early Access Program Availability | 0 | 356 | July 6, 2022 | |
Nvidia-fs MAP ioctl failed : ioctl_return: -22 ioctl_ret: -1 with GPU Direct Storage | 3 | 478 | March 22, 2024 | |
GPUDirect Storage | 6 | 1578 | February 25, 2024 | |
GPUDirect Storage: "Non-registered case, not yet implemented" error | 0 | 491 | May 19, 2023 |
