Is cuTENSOR supported on the Jetson AGX Xavier?
I want to make use of ITensorGPU on a Jetson AGX Xavier. It requires the cuTENSOR library. A moderator indicated that this cannot be done on the Jetson. Is this accurate? What are the alternatives?
Here is some info about my system:
┌ Info: System information:
│ CUDA toolkit 11.6, artifact installation
│ Unknown NVIDIA driver, for CUDA 11.4
│ CUDA driver 11.4
│ Libraries:
│ - CUBLAS: 11.8.1
│ - CURAND: 10.2.9
│ - CUFFT: 10.7.0
│ - CUSOLVER: 11.3.2
│ - CUSPARSE: 11.7.1
│ - CUPTI: 16.0.0
│ - NVML: missing
│ - CUDNN: 8.30.2 (for CUDA 11.5.0)
│ - CUTENSOR: 1.4.0 (for CUDA 11.5.0)
│ Toolchain:
│ - Julia: 1.7.3
│ - LLVM: 12.0.1
│ - PTX ISA support: 3.2, 4.0, 4.1, 4.2, 4.3, 5.0, 6.0, 6.1, 6.3, 6.4, 6.5, 7.0
│ - Device capability support: sm_35, sm_37, sm_50, sm_52, sm_53, sm_60, sm_61, sm_62, sm_70, sm_72, sm_75, sm_80
│ 1 device:
└   0: Xavier (sm_72, 10.216 GiB / 14.558 GiB available)
The cuTENSOR docs indicate the following:
Supported SM Architectures : SM 6.0, SM 7.0, SM 8.0
Does sm_72 mean SM 7.2? In this case, since cuTENSOR supports 7.0, should the Jetson AGX Xavier be supported?
In some cases, sm70 kernels can and will run onsm72 hardware, but this is not a guarantee. There is also the issue with compatibility between the software stack that builds the library and the execution environment. The only officially support GPU architectures are the data center cards, (i.e., SM X.0)
