Thanks for reaching out about CycloneDDS support for ROS2 Jazzy in Isaac Sim 5.0.0.
To help us understand the situation better and provide the most accurate information, could you please provide:
Specific references to the official documents you mentioned that indicate CycloneDDS support in v5.0.0 is only for ROS2 Humble? Providing links or quoting the relevant sections would be very helpful.
The exact messages or errors you see when launching Isaac Sim that suggest CycloneDDS isn’t supported for Jazzy. Please copy and paste the full output from your terminal if possible.
This information will help us investigate and confirm the current state of support and any plans for Jazzy.
Also when i launch the local build from source, i see these messages:
[23.196s] [ext: isaacsim.exp.full-5.0.0] startup
[23.239s] [ext: isaacsim.ros2.bridge-4.8.16] startup
[23.781s] Attempting to load system rclpy
[23.854s] Could not import system rclpy: No module named ‘rclpy._rclpy_pybind11’
The C extension ‘/opt/ros/jazzy/lib/python3.12/site-packages/_rclpy_pybind11.cpython-311-x86_64-linux-gnu.so’ isn’t present on the system. Please refer to ‘Installation troubleshooting — ROS 2 Documentation: Jazzy documentation’ for possible solutions
[23.854s] Attempting to load internal rclpy for ROS Distro: jazzy
[23.856s] Could not import internal rclpy: No module named ‘rclpy._rclpy_pybind11’
[23.856s] To use the internal libraries included with the extension please set the following environment variables to use with FastDDS (default) or CycloneDDS (ROS2 Humble only) before starting Isaac Sim:
2025-07-28T06:52:01Z [23,769ms] [Warning] [jazzy.rclpy] Could not import rclpy
Despite the error regarding loading the pybind11, because i am using a ROS-JAZZY container with default Python 3.12 while 5.0.0 uses 3.11, the messages related to DDS are clearly saying ROS2 HUmble only.
The documentation issue and messages have been addressed. The repo has been updated to RC.35. Please try with a fresh checkout for this and if you still see the messages, please ignore them. Thanks.
