Is enqueueV2 thread safe?
Description
The document clearly states that safe::IExecutionContext::enqueueV2 is NOT thread safe: link
But there is no description for the regular version of “enqueueV2”.
Currently, I’m using multithreading:
each thread creates its own nvinfer1::IExecutuionContext and cudaStream.
But I got wrong results with some random values.
If I make the calling of enqueueV2 sequentially, the result is OK:
   std::lock_guard<std::mutex> lk(io_mutex);
   ctx->enqueueV2(bindings.data(), stream, nullptr));
Environment
TensorRT Version:
GPU Type:
Nvidia Driver Version:
CUDA Version:
CUDNN Version:
Operating System + Version:
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
Please include:
  • Exact steps/commands to build your repro
  • Exact steps/commands to run your repro
  • Full traceback of errors encountered
The below links might be useful for you.
https://docs.nvidia.com/cuda/cuda-runtime-api/group__CUDART__STREAM.html
For multi-threading/streaming, will suggest you to use Deepstream or TRITON
For more details, we recommend you raise the query in Deepstream forum.
or
raise the query in Triton Inference Server Github instance issues section.
Based on the source code of trtexec, it looks like ExecutionContext::enqueueV2 IS thread safe because this is no mutex. Is that correct?
