Is GDS actually enabled on my system? gdscheck shows NVMe Unsupported but cuFile I/O works
I’m trying to verify whether GPUDirect Storage (GDS) is fully enabled on my system.
I installed the NVIDIA Open Kernel driver, CUDA toolkit, and GDS (nvidia-fs + libcufile). gdscheck reports a supported platform, but the device section still shows NVMe: Unsupported, which is confusing because gdsio achieves high GPU-direct throughput.
Here are the details.
1. gdscheck output
GDS release version: 1.13.0.11
nvidia_fs version:  2.26
libcufile version: 2.12
Platform: x86_64
DRIVER CONFIGURATION:
NVMe P2PDMA        : Unsupported
NVMe               : Unsupported
NVMeOF             : Unsupported
SCSI               : Unsupported
Userspace RDMA     : Unsupported
--rdma library        : Not Loaded (libcufile_rdma.so)
--rdma devices        : Not configured
GPU index 0 NVIDIA RTX A6000 bar:1 bar size (MiB):256 supports GDS
IOMMU State: Disabled
Platform verification succeeded
2. Filesystem & hardware info
My NVMe is mounted here:
/main-partition-samsung (ext4)
nvidia_fs is loaded:
nvidia_fs  274432  0
nvidia    11644928  3 nvidia_uvm,nvidia_fs,nvidia_modeset
Kernel:
Linux 6.8.0-85-generic
Driver supports CUDA 12.8:
Cuda Driver Version Installed: 12080
3. GDS I/O performance (gdsio)
Even though gdscheck shows NVMe as unsupported, gdsio gives very high throughput (3.8 GiB/s using GPU memory):
IoType: WRITE XferType: GPUD Threads: 4
Throughput: 3.827373 GiB/sec
Avg_Latency: 4050 usecs
This suggests that cuFile is taking the GDS path successfully.
4. My questions
(1) Is GDS actually enabled/active on this system, despite NVMe: Unsupported in gdscheck?
(2) Does “NVMe: Unsupported” indicate lack of peer-to-peer DMA capability (P2PDMA), or that the NVMe driver didn’t register with nvidia-fs?
(3) What exactly does gdscheck require for “NVMe: Supported”?
Is it only dependent on platform topology (ACS/IOMMU), or also NVMe firmware/driver specifics?
(4) Since gdsio achieves high GPU-direct throughput, is it safe to assume that cuFile → nvidia-fs → NVMe direct path is active?
Happy to provide:
  • /proc/driver/nvidia-fs/devices
  • /proc/driver/nvidia-fs/mounts
  • PCIe topology
  • NVMe controller details (lspci -vvv)
  • Kernel logs
Thanks in advance for any clarification!
1.Can you post complete gdscheck output as below there is cufile.json config and it might be that compat mode is enabled.
NVMe P2PDMA : Unsupported —→ Show P2PDMA Not supported
NVMe : Unsupported —-Show even nvidia-fs is not supported.
2.whats the GPU? Please paste ouytput of nvidia-smi
3. again it could be compat mode running posix API
4.1 - No
4.2 - Both
4.3 - nvme patched driver ( doca host) , nvidia-fs installation
