Hi all
i have a problem in setting multiple :
- i apply NvEnc in low latency mode (no B frames) and set dwMaxNumRefFrames=2
- In generated h264 stream the sequence header contains max_num_ref_frames=2 and moreover max_dec_buffering=2 (as expected when dwMaxNumRefFrames=2).
- However, in PPS header num_ref_idx_l0_active set to 1 (instead of 2) and all inter slices are coded in the single reference mode.
Apparently, NvEnc disables activation of multiple reference mode. Maybe because the low latency?
