Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.4.1.7402
other
Host Machine Version
native Ubuntu 18.04
other
while implementing a vehilceIO driver to communicate with a vehicle controller, I saw, that encoding a command does not result in the intended values in the CAN message.
Using this DBC file: oscc/oscc.dbc at master · PolySync/oscc · GitHub
With the following code:
status = dwCANInterpreter_encodef32(0.7f,
OSCC_ID_THROTTLE_COMMAND_PEDAL_REQUEST,
&msgCAN, gIntp);
checkError(result, status, "encode OSCC_ID_THROTTLE_COMMAND_PEDAL_REQUEST failed");
Results in the following message on the bus:
$candump -i vcan1,92:FF
vcan1 092 [8] 11001100 00000101 00000001 00000000 00000000 00000000 00000000 00000000
Trying to encode the value ‘1’ has the exact same result. Using ‘100.5’ leads to:
vcan1 092 [8] 11001100 00000101 01100101 00000000 00000000 00000000 00000000 00000000
Which is ‘101’.
So it seems the value is round and then not encoded using IEEE 754, but just encoded as integer number. Is “SIG_VALTYPE_ … :1” in *.dbc files not supported?
Are there any workarounds?
Regards
