Is installing Jetpack directly on the SSD not supported/recommended anymore after 6.1 rev.1?
I was about to make a clean install of Jetpack for my Orin Jetson Nano when I visited the official tutorial:
I recall that before there were clearly two options: Installing on the SD card or installing on the NVMe SSD directly via the SDK Manager. But now the procedure for the SSD is no longer described, and it is used merely as a secondary storage device.
Is there any issue with using only the SSD as before or is it just an oversight on the docs?
No. It’s fine to installing the NVMe or sd card.
