I have a brief question. I using many buffers in my kernel (up to 10) in order to reduce register pressure I was thinking to store the devPtr to the memory and the pitch-values in constant memory.
Is this advisable?
This is a problem where we require more information (like a code snippet) to provide specific advice, and it’s easy enough for you to try if your intended change really does reduce register pressure.
