Is It correct that secureboot_R32.3.1_aarch64.tbz2 is a latest thing?
Flashing with initrd
Applies to: Jetson Xavier NX and Jetson AGX Xavier series only
You can flash with initrd (initial RAM disk) to both internal media and external media connected to a Jetson device. This procedure uses initrd and USB device mode. It requires that the Secureboot package be installed; see Installing the Secureboot Package in the topic Secureboot.
Tools and instructions for flashing with initrd may be found in the directory /Linux_for_Tegra/‌tools/‌kernel_flash/. For more detailed information, see README_initrd_flash.txt in the same directory.
To flash jetson xavier nx with initrd, it require installing secure boot package.
Thank you.
You should be able to find it from each L4T release page, the R32.6.1 release page contain the package: Jetson Linux R32.6.1 Release Page | NVIDIA Developer
