I refer to the Drive px 2 hands-on.pdf file.
This file describes how to execute the following sample program.
A. NVIDIA_CUDA - 8.0 _ Samples fluidsGLES
B. DriveWorks Sample Applications sample_drivenet
I want to run B. But I do not know the relationship between B and A.
I understand that Samples’ fluidsGLES is a drawing sample.
Therefore, I want to know the relationship between A and B.
I ask you two questions.
Do I need to make A to run B?
If the answer to 1 is Yes, should I run Target Setup on the DrivePX 2 command prompt?
TegraA and TegraB are inter-connected with Ethernet over the Marvell Gb AVB switch.
They can communicate with each another through this network connection.
I don’t think you need to make A to run B. Thanks.
I have not understood much yet.
If you do not need a make file from the CUDA sample application,
What is the purpose of fluidsGLES?
I thought that fluidsGLES is a sample for rendering but is not it?
How does fluidsGLES relate to Ethernet’s Gb AVB?
I do not care about Tegara A / B.
I just want to run DriveWorks Sample Applications sample_drivenet on DrivePX2.
I am sad that I can not get an answer.
I do not have permission to view bin files and documents yet.
I will return to the first question.
I want to run 2. But I do not know the relationship between 2 and 1.
Therefore, I want to know the relationship between 1 and 2.
Quistion1. Do I need to make 1 to run 2?
Quistion2. If the answer to Quistion1 is Yes,
Dear shin.kishida.hf,
The fluidsGLES is a CUDA sample application and the sample_drivenet is a Driveworks sample application. There is no relationship between these two samples. You can run these samples independently.
